Old 05-06-2006, 03:03 PM   #1
andykay
Your Ride: 2001 325CI
Oil Drin Plug
Anybody got a pic of where the oil drain plug is?
Old 05-06-2006, 03:08 PM   #2
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Take a look at this diagram and see if it helps:
It's part 14-16
Welcome to ub.c
Old 05-06-2006, 05:45 PM   #3
Rate My Car: 106 / 337
^^^Correct me if I'm wrong, but I think it's part #3, and #4 is the crush ring
Old 05-06-2006, 05:48 PM   #4
nick_318is
nick_318is's Avatar
I think your right, my bad.
Old 05-06-2006, 08:31 PM   #5
RealBmw 02
Title: GRIP > DRIFT
Rate My Car: 78 / 337
anyone know what #14-16 actually is then? Oil temp or low oil sensor?
1970 BMW 2002
Driven by skill, not money
Old 05-06-2006, 11:23 PM   #6
nick_318is
nick_318is's Avatar
^its a sensor, i looked it back up
Old 05-07-2006, 11:27 AM   #7
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
If you jack your car up on jack stands and look diretly under the ending you will see a large silver metal plate that protects the oil pan and surrounding objects. There will be a square cut out, Ide say about 4x6 in the center, a 17mm plug will be in there. Thats your drain plug, dont forget to loosen the oil filter and oil cap before draining.
I'm leaking oil, any suggestions nick_318is E21, E30 27 03-03-2012 03:15 PM
Spark plug replacement & compression test DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 21 10-18-2010 10:22 PM
Amsoil rocks. catalyst E36 26 02-23-2006 11:35 AM
oil change disaster!!! bimmerdame E36 25 05-25-2005 04:26 PM
