Old 02-12-2006, 09:33 AM   #1
ferracci69
Thumbs up And the winner is.........
Autohausaz! Yup, I looked every store possible for the plethora of parts that I will be purchasing and they are the cheapest with free shipping. These are the following parts that I will be buying:
Pagid
Brake Pad Set; Front; OE Compound $54.60
Pagid
Brake Pad Set; Rear; OE Compound $45.44
Pex/Elca
Brake Pad Wear Sensor; Front; 670mm with Elbow $9.95
Pex/Elca
Brake Pad Wear Sensor; Rear; 1410mm with Elbow $8.90
Bosch
Cabin Air/Pollen Filter; With Activated Charcoal $19.84
CRP-Continental
Cooling/Coolant Hose; Water Pipe to Expansion Tank $16.83
Mahle
Fuel Filter; With Pressure Regulator $40.61
BMW (OE)
BMW Antifreeze; 1 Gallon $23.57
Lubro Moly
Jectron Fuel Injection Cleaner; 300ml Can $6.35
Lubro Moly
Miscellaneous Fluids/Treatments; Sauber Valve Cleaner;Gasoline Additive; 150ml Can $4.95
BMW (OE)/CRP-Continental
Radiator Hose; Lower to Thermostat Housing with Temperature Sensor Fitting $17.55
BMW (OE)
Radiator Hose; Upper Radiator to Thermostat Housing $24.85
Conti-Contitech
Serpentine Belt/Ribbed Drive Belt; AC Compressor $9.59
Conti-Contitech
Serpentine Belt/Ribbed Drive Belt; Alternator/Pwer Steering/Wter Pump $16.29
Wahler
Thermostat; Thermostat Kit with Housing and Seal $59.71
Graf
Water Pump; Update Replacement with Metal Impeller and Gasket $59.07
Total bill: $438
If anyone has any suggestions or other options for a better make then the ones above please chime in and let me know. I would greatly appreciate it. However other online stores were between $480- $530. Now to find a reputable indy shop around my area.
Old 02-12-2006, 11:25 AM   #2
Rate My Car: 80 / 329
Nice
Old 02-12-2006, 12:11 PM   #3
Storamin
Storamin's Avatar
Title: Road Kill
20$ says you could install all that yourself.
Old 02-12-2006, 12:15 PM   #4
ferracci69
Wanna help, since you are not too far away from me. Let's say i'll hook you up with some cash, beer, and pizza...
I'm going to try and install everything, but the belts, water pump, and thermostat.
Old 02-12-2006, 12:59 PM   #5
doughboyea
doughboyea's Avatar
Your Ride: 2007 Acura TSX
What you pay individually...?
I normally go to Autoparts.com for most of the small stuff. Tirerack has cheap prices too sometimes. Umm, there's also circleBMW. They have the more harder to get parts sometimes. Usually cheaper than online. Can call them up and they ship it out to you. I haven't purchased from them in over a year, but it's just another option.
Unless i'm not reading your post accuratly...meaning, that you've already purchased all your parts already?
Dough
Current Ride
2007 Acura TSX w/Navi
Past rides:
1989 Mercedes 190E 2.6
1980 Mercedes 240D
Old 02-12-2006, 02:05 PM   #6
ferracci69
I have yet to purchase the parts. See above, i have put the prices for each.
Old 02-12-2006, 06:44 PM   #7
doughboyea
doughboyea's Avatar
ok, well i went though half your list and damn, i couldn't surpass it (differences from change to $10s). What's your source, Autohausaz and anything else?
Dough
Current Ride
Past rides:
1980 Mercedes 240D
Old 02-12-2006, 07:24 PM   #8
ferracci69
Well, i checked out Bimmerzone, BavAuto, AutoWerkes, and Pelican Parts, and they were between $480-$530
Old 02-12-2006, 07:37 PM   #9
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 72 / 329
Your Ride: 1995 M3
Very nice, haha. Seems like great prices across the board.
And the free shipping is the iceing on the cake.
Old 02-12-2006, 08:12 PM   #10
Spieluhr
Title: ///M Driven
yeah man, autohausaz.com has the best prices. and with their free shipping, you just can't beat it.
Old 02-12-2006, 08:56 PM   #11
Storamin
Storamin's Avatar
Title: Road Kill
sounds like fun. details?
Old 02-13-2006, 01:40 PM   #12
ferracci69
Let's see i called the nearest dealership in my area and they wanted $1300 to install...YEAH RIGHT!
This one shop i called said that, since i already have the parts that the hourly rate will go from $60 to $90...
I called an independent shop and he said he will charge me $325 for labor.
Can't beat that with a bat.
Old 02-13-2006, 02:54 PM   #13
///M Power
Rate My Car: 23 / 329
Your Ride: 95 m3 turbo
You can get better brake pads for the same price or cheaper from www.turnermotorsport.com
Axxis metal masters are cheaper. Axxis ultimates are about the same price. Also your local autozone and such might have the hoses you need.
Old 02-13-2006, 03:20 PM   #14
doughboyea
doughboyea's Avatar
If you got a bentley manual... it may help you do the rest. They run in the ~$80+ range.
Dough
Current Ride
Past rides:
1980 Mercedes 240D
Old 02-15-2006, 08:56 PM   #15
ferracci69
Nope, unfortunately don't have a Bentley Manual...not yet that is for sure. Thanks for inquiring about it.
