Old 02-07-2006, 08:04 PM   #1
EcianIce
EcianIce's Avatar
Your Ride: Nothing .. for now.
My Car Broke. :(
It ran fine yesterday. I hadn't really driven my car hard other than 110 down the freeway and 90 or so down the roads by my house night before it broke. Anyways, I get up for school and turn it on. Starts shaking really bad, settles out a bit but it's still not right.
I back out thinking it's just comming out of the cold from sitting for about 20 hours. Drive it up the street and the engine light comes on so I park it back in the garrage.
Get back home and take a look at it. Friend thinks it could be a vaccum leak or collapsed cat. Wasn't sure how to check for that without having codes pulled. Anyways, I thought about the cat. and checked the exhaust. Two tips, one blowing air .. and the other alternating in and out with air. In rythm with the engine cycles.
No idea what that means except that something is wrong in just one, possibly two cylinders being as only one tip is acting up like that.
Any idea?
Member of the First 5 Uniters.
Old 02-07-2006, 08:12 PM   #2
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 72 / 329
Your Ride: 1995 M3
I bought that OBD2 code reader... I could pull your codes this weekend (wow that sounds wrong).
Old 02-07-2006, 09:01 PM   #3
doughboyea
doughboyea's Avatar
Your Ride: 2007 Acura TSX
You still under warrenty? That does sound really messed up... I've never delt with that personally though. I'm curious to know what caused this....
Dough
Current Ride
2007 Acura TSX w/Navi
Past rides:
1989 Mercedes 190E 2.6
1980 Mercedes 240D
Old 02-07-2006, 09:09 PM   #4
EcianIce
EcianIce's Avatar
I'd love for you to pull my codes Harry. As long as we can cuddle after. ^^;
Old 02-07-2006, 09:18 PM   #5
komodo
komodo's Avatar
Your Ride: 1995 M3
Old 02-07-2006, 09:48 PM   #6
Spieluhr
Title: ///M Driven
your exhaust thing sounds normal. A lot of exhausts only open one side part of the time when idle. It helps build up back pressure and torque.
Is the idle rough? Does it feel like it doesnt have as much power? You might want to check that your spark plugs are ok, and that all cylinders are firing correctly.
Hook up with harry, and get the codes read.
Old 02-07-2006, 10:35 PM   #7
Rate My Car: 173 / 329
it may be something very minor, 02 sensor maybe, that exhaust blower fan thing that goes wrong with the OBDII cars
Old 02-07-2006, 11:33 PM   #8
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 329
Heres one, probably not it, but is your oil cap on, i had an incident where i forgot to put mine on and the car was pretty unhappy until i realized it.
Old 02-08-2006, 04:11 PM   #9
Storamin
Storamin's Avatar
Title: Road Kill
i once forgot my oil cap... car was fine. then i went to the track the next day and realized during tech i had no oil cap. luckily my z3 one fit... thank god.
Old 02-08-2006, 04:40 PM   #10
EcianIce
EcianIce's Avatar
i don't think the exhaust thing is normal. it didn't do that before at least. but yea, the car drives like normal but it's just outta sync or something. we're taking it in tomorrow i believe.
my first thought was spark plugs or fuel injector got blocked up. air flows fine so no vaccum leaks i think. anyways - codes will tell.
Old 02-08-2006, 04:43 PM   #11
komodo
komodo's Avatar
Your Ride: 1995 M3
Autozone will read codes for free.
Old 02-08-2006, 04:56 PM   #12
DEATH2000
DEATH2000's Avatar
Rate My Car: 123 / 329
Means less time wasted cuddling.....
Old 02-08-2006, 06:52 PM   #13
Antiburn
Antiburn's Avatar
Rate My Car: 176 / 329
Check your coils, there is a recall for out of date coils. They cause check engine light and misfire. Pull a coil out, if its all black then you need the updated ones. Check all 6 cylinders too. You car should still be under warranty unless youve over-ran the milage so they will give them to you for free.
Old 02-08-2006, 06:56 PM   #14
komodo
komodo's Avatar
Your Ride: 1995 M3
Cuddling is never time wasted.
Old 02-09-2006, 09:14 AM   #15
EcianIce
EcianIce's Avatar
define: coils.
The Laws of a Ricer komodo Comedy Collection
24 01-22-2008 05:54 PM
You Might Be a Ricer If.... komodo Comedy Collection
20 11-08-2006 11:06 AM
My car exploded, and other hell from the past two days. (pics) komodo E36 120 02-17-2006 01:31 PM
What Car Did Your Father/Parents drive or have driven? delmarco United Off Topic  **FOR MEMBERS ONLY** 8 09-18-2005 02:17 AM
Rate My Car Has Gone Live!! komodo Site Feedback 70 05-20-2005 07:28 PM
