Old 01-17-2006, 05:20 PM   #1
Timboy
Brake question......
To remove the caliper bolt, what mm (allen key) is the caliper bolt, i cant remeber????
Who U are, U are Forever.....
Oh I collect stamps alright, I keep them in my Passport!!!
I am nobody----nobody's perfect----therefore, I am perfect!
I am a product of curiosity!
Old 01-17-2006, 05:29 PM   #2
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 329
I believe its 7mm
Old 01-17-2006, 07:52 PM   #3
Timboy
i think you're right, its the same on my e36....probably most all bimmers
Thanks for the reply
Old 01-17-2006, 09:03 PM   #4
nick_318is
nick_318is's Avatar
no problem good luck with brake work
Old 01-17-2006, 11:54 PM   #5
Storamin
Storamin's Avatar
Title: Road Kill
Which caliper bolt is allen? The only things I can think of that have allen on the front are the wheel speed sensor and the rotor bolt.
Old 01-18-2006, 12:41 AM   #6
nick_318is
nick_318is's Avatar
i know my rears the caliper guide bolts are the 7mm allen hex.
Old 01-18-2006, 04:53 AM   #7
Rate My Car: 102 / 329
Yea, the caliper guide bolts are allens, once you pry off the covers.
Old 01-18-2006, 04:02 PM   #8
Storamin
Storamin's Avatar
Title: Road Kill
I could have sworn mine were Torx. The bolt that holds my rotor to the hub assembly is an allen. The caliper guide bolt is different than the rotor to hub assembly bolt.
Old 01-18-2006, 05:41 PM   #9
Hmm . . maybe they're Torx on some, but I doubt it. All the photos I've ever seen use Allens, like the one below. Can't speak for my E36 as I have yet to change the pads.
Old 01-18-2006, 06:23 PM   #10
Storamin
Storamin's Avatar
Title: Road Kill
Mine are different than that. Mine are torx on all 4 calipers.
DIY Brake Pad Change nick_318is BMW OEM Parts Department DIY's & FAQ's 6 08-25-2011 10:23 PM
BMW Inspection Rooz BMW General Discussion 21 03-14-2006 02:10 PM
Upgraded Brake Lines dinan540 BMW General Discussion 10 01-25-2006 02:27 AM
E30 Brake Pad Changing Procedure nick_318is BMW OEM Parts Department DIY's & FAQ's 6 10-14-2005 06:36 PM
Quality Brake Package (rotors, pads, lines) Spieluhr Vendor/Dealer Comments & Supporting Vendor Announcements 2 08-28-2005 03:05 PM
