| E46 General discussion and technical help for 1999-2004 3 series cars. |
View Poll Results: What Brake Upgrade Should I Do?
Cross-Drilled Rotor Upgrade?
2 |
33.33% |
Slotted Rotor Upgrade?
0 |
0% |
New OEM Rotors?
4 |
66.67% |
Screw it, and just get new pads?
0 |
0% |
01-04-2006, 05:15 PM
#1
Your Ride: 2001 330i
Brake Upgrade
OK, I've read all the old threads about cross drilled and slotted brakes...the time has come to make a purchase.
Do I do it, or do I not?
You help me decide.
Proud member of the Roundel Avatar Club!!
01-04-2006, 06:24 PM
#2
Your Ride: 1994 325is
If you just change the pads theres a good chance youll get vibrations up front, so do both rotors and pads at the same time.
Slotted are better than oem, but not really worth the money unless you go with good pads and are going to track the car.
01-04-2006, 08:14 PM
#3
Your Ride: 1995 540LE
01-04-2006, 10:11 PM
#4
Title: Road Kill
you can probaly have the old rotors turned... unless they're below the wear marker. if they are, just buy new OEM blanks and aftermarket pads.
