Old 11-05-2005, 06:36 PM   #1
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 128 / 329
Your Ride: ^^
Exclamation 330 not starting....
ok so we ggot a steep driveway, and the 330 wont start if its faced down hill. it makes a sound slike the started went out or something. it clicks, the lights flash as if its starting and then nothing. no turn over or anthing. weird thing is if i put the car on the same driveway faceing upwards(fron of car is at top of grade) then it doesnt do it. The symptoms go away as sonn as u put the car on flat land and giv it five minutes. any ideas?
Old 11-05-2005, 07:27 PM   #2
Rate My Car: 173 / 329
we also have an extrmely steep driveway, it did something similar, first of all, our battery was practically dead, but it only happened once, but on the driveway, u come to start it, it just whines, roll down the hill and on the road, u can start it fine, it sounded like the starter was slipping b/c every once in a while it would catch and the car would ALMOST turn on but not really
Old 11-05-2005, 10:18 PM   #3
Antiburn
Antiburn's Avatar
Rate My Car: 176 / 329
If your gas tank full when you try it.
Old 11-06-2005, 02:05 AM   #4
Numark318i
Numark318i's Avatar
Your Ride: ^^
sounds right.
anyway to fix it?
edit* as u see in the sig the 330 would be parked exactly like that. that part of the driveway isnt THAT steep.
Old 11-06-2005, 02:18 AM   #5
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
It's the battery.
When the lights flash...and it goes click, click, click. It's the battery.
Old 11-06-2005, 07:43 AM   #6
Antiburn
Antiburn's Avatar
Cheapest way to get a fix, first test your battery, you dont need to replace it if its not bad. 2nd if its bad, replace it with a BMW OEM battery. I believe for you car it goes for 100-150$.
Old 11-06-2005, 08:09 AM   #7
Rate My Car: 102 / 329
Could be something to do with the fluids in the battery. Instead of turning the car around, turn the battery around or tilt it to level, and see if it starts then?
Old 11-09-2005, 11:13 AM   #8
EcianIce
EcianIce's Avatar
Your Ride: Nothing .. for now.
thats a very odd problem to have but its not that far fetched. agreed on the advice of checking the batery / leveling it.
i'm interested to know if that is actualy the problem
Member of the First 5 Uniters.
Old 11-09-2005, 02:29 PM   #9
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 72 / 329
Your Ride: 1995 M3
He's alive!
Old 12-12-2005, 07:13 PM   #10
Numark318i
Numark318i's Avatar
Your Ride: ^^
update
yea it was the battery.
cost us 172 dollars with tax.
fixed the problem. the car starts like a dream once again.
Old 12-12-2005, 07:18 PM   #11
komodo
komodo's Avatar
Your Ride: 1995 M3
$172 for a battery? Damn.
I paid like $110 for mine and got a high end one.
Old 12-12-2005, 10:24 PM   #12
Numark318i
Numark318i's Avatar
Your Ride: ^^
it was a BMW battery. I guess the battery has a huge voltage(..or what ever they measure it in) so no other companies make them that strong. we called 5 places before bmw.
antenna options for E46 330 Numark318i E46 9 01-13-2006 03:17 PM
drove the new 330 beem E90 29 08-24-2005 08:16 PM
New e90, 330 Prem, Cold, Sport, Alum Trim e90jimmy E90 23 05-30-2005 02:27 AM
Trouble starting car after sitting cold for 3 days..help!? delmarco E36 2 05-28-2005 10:26 AM
