Old 11-28-2011, 08:43 AM   #1
bcaughhorn
Your Ride: 02 330ci
02 330ci key wont unlock the door.. help
my wife drives a 02 330ci. when we got the car the key fob didnt work. no big deal we have just been using the key to unlock the door. now the key will not turn left in the door. it turns to the right smooth as always. it will not turn to the left the least little bit. im not the tallest at 5'8" and 185lbs but crawling through the trunk isnt something i like to do. i pulled a fuse out so the doors wouldnt lock until i can figure something out.
can somebody help me out???????????? ive already posted this on 2 other forums with no help
Old 11-28-2011, 10:40 AM   #2
Big Evil
Big Evil's Avatar
Broken shear pin. You need the door lock replaced
Old 11-28-2011, 12:48 PM   #3
bcaughhorn
Your Ride: 02 330ci
ok thanks. i called bmw in mobile and ask about it. i figured they had to order it. he said 2 to 3 days and 152$ but there is other parts i need to check out too that work with the cylinder. does anybody have a diagram on the locking in the door??
04 crew cab frontier v6 auto (mine)
02 330ci (wifes)
Old 12-18-2011, 02:00 PM   #4
DEATH2000
DEATH2000's Avatar
Rate My Car: 111 / 340
Check out www.realoem.com for part diagrams. Also, ECS Tuning carries door lock parts and they may have one for cheaper.
Old 12-18-2011, 02:04 PM   #5
bcaughhorn
Your Ride: 02 330ci
Ok. Thanks. I haven't even had time to look at the car yet with everything going on rite now. I guess ill get into it after christmas
02 330ci (wifes)
Old 01-04-2012, 12:18 PM   #6
lopezpaul
Your Ride: Honda Civic
door lock replaced i did it but after doing the door lock once again i faced the same problem i did not y?
Performance Chips
Old 01-04-2012, 01:00 PM   #7
DEATH2000
DEATH2000's Avatar
Sorry, do you mean that you replaced the door lock yourself and now your facing the same problem?
Key won't unlock door - can't get in bigandspeckie E46 2 01-03-2011 01:27 AM
Removing door lock cylinder Romee E21, E30 7 11-14-2007 06:13 PM
Rants on OS X and Installing Gentoo on my Powerbook komodo Geek Chat 18 04-22-2006 03:16 AM
Driver 's door key lock problem singring E36 2 12-29-2005 06:04 AM
