Old 03-19-2011, 04:00 PM   #1
lodave
Your Ride: 2002 325i Sport Wagon
Question Cleaning recalcitrant windshield washer nozzles
2002 325iT (E46) wagon, 88k miles, has had the washer reservoir pump recently replaced but the spray is inconsistent and uneven from the nozzles. How does one remove the nozzles to clean them thoroughly (or do they need replacement)?
Old 03-23-2011, 07:29 PM   #2
Big Evil
Big Evil's Avatar
Use a straight pin. If that doesn't work you can remove and soak them in Lime away. If that doesn't do it, replace them.
Old 03-24-2011, 09:16 AM   #3
Manolito
Rate My Car: 337 / 340
I have a similar problem with my wife's 04. The e36s had separate check valves beneath the nozzles that would get old and need replacement every decade or so, but I have not figured out where the check valves are in the e46, if it uses them at all.
Water is very hard where I live so I use distilled water in the windshield water reservoir. I have been using it in all my cars for 30 years. I probably use only a gallon a year in each car so the cost is negligible. That keeps the nozzles from getting dirty, but I still have erratic spray on the '04.
You may find that most stick pins are too large in diameter, but sewing needles are made thinner, or a wire from a steel brush should work.
windshield washer stoped working feethurt E12, E28, E34, E39, E60 0 12-19-2009 07:24 AM
Happy boy! Windshield washer works! jerryd E12, E28, E34, E39, E60 0 05-03-2007 08:58 PM
Windshield washer doesn't work jerryd E12, E28, E34, E39, E60 9 05-03-2007 08:50 PM
wehere is the sensor for the windshield washer impersus E12, E28, E34, E39, E60 2 04-12-2007 12:27 AM
Windshield Washer Spray System projal147 E36 2 04-27-2006 05:01 PM
