Old 08-16-2010, 12:35 PM   #1
jaylee0128
Your Ride: 2001 bmw 3.25i
2001 bmw 3.25i please help with problem
Takes longer to start, and idles BAD. When accelerating it feels like I have about half the power, and rpms jump and stop without being smooth.
I ran a scan and the camshaft and crankshaft position sensors showed up.
What makes it complicated is when it first started doing this the abs light came on as well. So i dont know if the problems are connected or not.
I changed both sensors, but im still having the problem.
The camshaft sensor code isnt showing up anymore, but the crankshaft is still showing. I erased the codes after changing and it popped back it up.
I didnt know if someone knew of something that could trigger the abs with the crankshaft code, or is it just a weird coincidence.
Hopefully someone has had a similar problem, or a good idea of how to fix it without giving the dealer thousands of dollars.
Old 08-19-2010, 09:49 AM   #2
Big Evil
Big Evil's Avatar
Aftermarket sensors can be bad right out of the box, or you have a wiring issue. Start there. The ABS with the crank could just be a fluke or there's a wiring problem and they're in the same harness. Trace it, track it and see what you find.
Help!!! 2001 325Ci clutch problem tmenter E46 0 03-19-2009 08:41 PM
BMW 320i Gas Problem rOMa E36 5 06-27-2007 02:40 AM
