Old 01-29-2010, 01:31 PM   #1
elisa
Your Ride: 2002 325i
Emergercy Flashers going crazy!
I have a 2002 325i. The emergency flashers come on and off by there self. Also the locks unlock and lock just randomly while I am driving. I replaced the emergency flasher switch but this did not fix the problam. Does any one have any suggestions? Thanks
Old 02-05-2010, 10:30 AM   #2
k3nd0
Your Ride: e46, e28
Shorted to ground.
Elisa,
I pulled the schematics for the circuits you're having issues with and both switches are in the same unit and share a ground wire. If the switch is a known good part then you have a short to ground in the circuit. I would pull out the switch and inspect the connector and wires for any loose or exposed wires.
I would strongly suggest having a competent tech do the work for you unless you have a good understanding of electrical systems. Did you replace the switch yourself or did a tech do it? The switch would have been my first guess and they weren't necessarily wrong to replace it. EDIT: I originally said they should be able to prove that the switch was faulty but because it's an intermittent issue it would be very difficult to prove. Still, you may want to talk to them about reimbursing any parts and labor for replacing the switch. Also, you should not pay them again for diagnosis as they did not diagnose it right the first time.
I read your other thread where you said you were having transmission problems. This particular switch is located directly above the transmission, and any kind of funky wiring where B+ is becoming grounded to the transmission case could definitely cause faults with the transmission module. I would definitely fix the wiring before you consider anytransmission work.
Good luck,
k
emergency flashers bartelsmeyer E36 8 01-29-2010 01:34 PM
tempreture gauge gone crazy?!?!? jamesbmw320i E21, E30 6 04-07-2007 06:10 PM
Crazy experiences TJsBimm United Off Topic  **FOR MEMBERS ONLY** 10 01-02-2006 08:36 PM
Crazy alarm nino E12, E28, E34, E39, E60 1 11-28-2005 09:11 PM
More of those crazy Arabs defkon99 Video and other Multimedia 4 08-21-2005 10:13 AM
