Old 12-07-2007, 08:31 PM   #1
chris3896
Your Ride: 2000 323i
1999 323i Bogging
Hello everyone. I have a 1999 323i with 5-speed and 105,000 miles. I recently started experiencing a random group of problems with my car. I think it could be clutch wear but I am not really sure.
1. The car bogs when I am below 2000 rpms, usually around 1800rpms. It kind of "slips" and shudders. Sometimes it persists through 2000 all the way to 3000. Other times it just stops at 2000 and acceleration continues.
2. I have to ride the clutch a lot in first gear to get it to engage. Almost have to rev it to 2000 before I semi-drop the clutch to keep it from stalling.
3. I thought it was the spark plugs since it had been awhile, but I changed those out not a week ago and that didn't fix it. I am due for an oil change soon but I don't think that is part of the problem.
4. My clutch was replaced with a Sach's clutch about 30,000 miles ago.
5. Acceleration is a little slower than I remember. The tach needle almost shudders sometimes as it is accelerating.
6. Even more recently, within the past week (this has been going on for almost 3 weeks now), the car will all of a sudden throw a check engine light (little yellow one with the box and lines) and the car will shudder almost like the car is "gasping for air" or "tired". If I turn the car off and crank it again the problem is remedied.
Anyone have any ideas as to what could be causing this? I am thinking new clutch but I wouldn't think I would need a new clutch that fast nor it would fix the shudder that I am getting and the check engine light problem.
Thanks,
Chris
Old 12-07-2007, 09:09 PM   #2
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
Check faults would be your first thing to do.
Possible cam sensor causing your missfire, but theres a possibility of 20 + other things that might be the problem.
Old 12-07-2007, 09:33 PM   #3
TECH
Your Ride: Sick cars.
Yep, check faults. A clutch isn't going to make the engine run poorly. Something simple, check both battery terminal connections and the ground to the body-make sure everything is tight. Make sure the jump point under the hood isn't burned or loose.
Old 12-09-2007, 06:46 PM   #4
chris3896
Will do. Hope it's nothing serious.
Old 01-20-2008, 09:04 PM   #5
chris3896
Turns out it was the ignition coils. $70 dollars a piece. Turns out the boots were also bad too and had sparked the spark plugs down the side and I had to replace the spark plugs AGAIN even though I had just replaced them two weeks prior. Gross.
Old 02-21-2009, 06:47 PM   #6
Justa523ise
Justa523ise's Avatar
Your Ride: 1996 523ise & a Transit lol
I am experiencing a very similar problem with my 523i. sometimes its fine and sometimes the engine is very "lumpy" when accelerating. It has been known in the past few days to just cut out when its on idle.
Someone suggested on this thread a Cam Sensor, not thought of that so will check that.
Any other suggestions???
1999 323I right wheel oil leak M3ltdown E46 11 09-04-2007 09:22 PM
1999 328i - Please Help. ksmillig E46 4 08-12-2007 09:46 PM
S1 Package-Manual 323i - dinan CAKONVIKT E46 3 05-08-2007 10:31 AM
1999 328i for sale ksleath Bmw Cars For Sale/Wanted 3 05-01-2007 11:03 AM
carfax pls! zenon United Off Topic  **FOR MEMBERS ONLY** 2 05-22-2005 02:37 PM
