| E46 General discussion and technical help for 1999-2004 3 series cars. |
11-23-2007, 02:19 PM
#1
Your Ride: 1999 328i
bad plugs
ok so i did the ohms test on coil packs all came out good
put in new plugs and still fowled out #2
changed around coil pack still no diff
any help
11-23-2007, 03:15 PM
#2
Did you check for voltage at the ignition wire? Physically inspect the ignition harness as well- there are many documented cases of wire chafing or breakage on E36/46 models.
Plug is fowling? what does it look like?
11-23-2007, 04:10 PM
#3
no wire chafe or breakage that is visable bye eye
and wet gas really black
puled wireing off while running #1,2,and4 made no diffrence so my next ? is what would run just those cyl i.e. sensor or mod
11-23-2007, 04:36 PM
#4
On the M50 engine, the ignition wiring leads to thinner wires located inside a long plastic box sitting above the fuel rail. Inside this is where the chafing or breakage occurs. Not sure if the wiring is the same for your M52 engine, I think it would be the same. You didn't answer whether you checked for voltage at the plug harness.
Unburned fuel could mean a few things. Depending on your mileage, your fuel pressure regulator could be toast. Is the car losing power or stalling? Any smoke coming out of the rear pipes? If so, I wouldn't drive the car like that, or you'll damage the O2 sensors and/or the catalytic converter.
11-23-2007, 04:59 PM
#5
no test on wires not the sparky type guy and this is my first bmw
so i am try to learn as i go
i can fix just about any other car so not afraid just dont got the right tester,s yet
and not sure witch one to buy obd2 or bmw round
drive it like you stole it!!!  !!!
