Old 09-03-2007, 03:57 PM   #1
M3ltdown
Your Ride: 2000 323i
1999 323I right wheel oil leak
hi i have a problem with my 1999-2000 323i , i have oil marks and some oil droplets dropping form the driver side front wheel, the oil seems to have splattered all over the inside of the fender, as if it was spread by the wheel, (pic could b made available) any one have any idea what this is? coudl it be brake oil? Engine oil? please help me out
Post questions or anything ill give u feedback asap.
Old 09-03-2007, 04:11 PM   #2
Rate My Car: 183 / 337
thats really interesting, if it was an XI i would say maybe your CV-shaft, but then you leave me clueless
Old 09-03-2007, 04:31 PM   #3
M3ltdown
ok well i cleaned it off im going to take it for a ride to see if the oil issue persisits.
Old 09-03-2007, 07:00 PM   #4
Rate My Car: 106 / 337
Could it be coming from your strut?
Old 09-04-2007, 05:23 PM   #5
M3ltdown
could it be the power steering?
Old 09-04-2007, 05:40 PM   #6
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
Did you run over a oil bottle? Or hit a puddle of it?
Old 09-04-2007, 06:35 PM   #7
M3ltdown
im nto leaving that hypothesis out the question but i checked the oil guage for the power steering and the oil is pretty low? could it be i found a power steering leak?
Old 09-04-2007, 06:48 PM   #8
^^^If so, it's gonna be red, and you probably know what ATF smells like.
Old 09-04-2007, 08:16 PM   #9
M3ltdown
Yes it seems to be red atf oil, it is probably the powersteering, anyone knwo how much this repair might cost, expensive, normal, cheap? also is it the type of repair that requires dealer mechanics?
Old 09-04-2007, 09:08 PM   #10
you didnt notice the lack of power steering?
Old 09-04-2007, 09:22 PM   #11
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
where is it leaking from?
if it is leaking from the resevoir its relatively easy to fix.
any other leaks will require new crush washers for the banjo bolts in the pump.
hopefully its not you high pressure hoses that are leaking, they are pricey
Old 09-04-2007, 09:22 PM   #12
Rate My Car: 84 / 337
When mine started leaking, I barely noticed the low power steering.
oil leak in 94 730i BMW730i 7 Series (E23, E32, E38, E65, E66) 6 08-21-2007 08:28 PM
Oil leak Belal Salem E36 3 06-09-2007 08:48 AM
FUN oil leak xxxbimmer E36 8 12-28-2005 02:03 PM
DIY: Add M3 steel guage rings to E36+ Remove Steering Wheel & Cluster. (pics) delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-09-2005 12:05 PM
