Old 08-27-2007, 11:09 PM   #1
pierocastel
pierocastel's Avatar
Your Ride: BMW 2001 325I SEDAN
Hey I just paid $4 for the wiring schematics for my 325i e46 2001 4 dr sedan. I was useless for what I need.
MY question is if anyone knows the wiring info for installing colored gauge face plates.
Old 08-27-2007, 11:11 PM   #2
pierocastel
Also I got the DIY info from this forum and just installed chrome gauge rings. It was easy with the directions. But now my clock on my radio is blank. any suggestions
Old 08-27-2007, 11:18 PM   #3
pierocastel
DIY-Clored gauge face plates
Has anyone here installed the Gauge face plates and if so
Where can I get wiring info on the 325i e46 2001 4 dr sedan so I dont mess up the entire panel. There are a lot of wires behind the dash, Where does the connection happen.
Does anyone have pictures of the process.
Thanks
Piero
Old 08-27-2007, 11:21 PM   #4
pierocastel
Looking for a thread with active participants. Buy hey just started a new thread
Do you have any suggestions!
Old 08-27-2007, 11:25 PM   #5
scooter
scooter's Avatar
Title: Administrator
Rate My Car: 228 / 245
Your Ride: 99m3
the face is just an overlay, you dont have any wires to worry about, pull the cluster out and remove the plugs, then the needles and then you can peel off the face and replace it with the new one.
[UB]
Old 08-28-2007, 08:24 PM   #6
pierocastel
This is what the El-Glo overlay gauge faces look like.
I have no idea where the switch is suppose to end up. Also having difficulty understanding the directions they enclosed.
I purchased wiring info from Wirediagram.com on my make and model car.
Old 08-28-2007, 10:28 PM   #7
Rooz
Rooz's Avatar
Rate My Car: 70 / 245
Your Ride: 2004 ZHP & 2002 330i
When do you want it to glow? When you put the key in, or when you turn your parking lights on?
VIEW MOD LIST & PICS
Originally Posted by Gregg
Umnitza now provides a mechanic to install all parts ordered right in the box! It's their new "Total customer service program" that will eliminate all the haters and keep incompetents from breaking shit and blaming the vendor! When you are all set simply call INS and they will pick him up free of charge.
Old 08-28-2007, 10:51 PM   #8
pierocastel
thanks
I would like them to go on with the lights. The wire diagram that I purchased lists the parking lights as Security
Parking Ligths
FORTH WIRE FROM THE LEFT LOOKING AT SWITCH IN RIBBON CABLE
(WHAT IS SWITCH IN RIBBON CABLE AN WHERE IS IT LOCATED)
Also if you look at the picture of the wires for the gauge faces, there is a switch that allows the change of the LED from Blue to Green and the intensity of the color, where would I mount this.
Old 08-28-2007, 11:09 PM   #9
pierocastel
there are also more male plugs than female inserts, then there are two loose ends one Black (positive) and Red (negative) but the directions do not mention anything about this. the wiring diagram for my car does not mention whether this connection is +/- like toher items on the diagram list, should I attach one or the other
Old 08-28-2007, 11:14 PM   #10
Rooz
Rooz's Avatar
IF I were you, I'd buy a test light and just test to see what wire gets some power when you turn your parking lights on and just tap into it for those gauges.
Old 08-28-2007, 11:39 PM   #11
pierocastel
I am expanding the pictures of the entire system.
Just to give a more clear understanding to those in the know. Thanks again.
Old 08-29-2007, 12:01 AM   #12
pierocastel
tahnks i didnt see that you responded so i added pictures. Question is now, do i connect the + or the - or both?
vB code is On
