Old 08-17-2007, 07:54 PM   #1
bbainmd
Your Ride: 2001 325
Shifter assembly replacement???
Hi! seeking advice:
My 2001 325 has just over 3,000 miles. the steptronic shift lever suddenly was 'catching" going from neutral to drive. My local BMW dealer found the"shifter pin was broken and hitting the stop gate". They filed the stop gate slightly to help the pin move more smoothly- total bill $121.81 . They say I need to replace the shifter assembly, they had to order the part, and it will cost $633.50 to replace.
The shift lever works fine now; the transmission continues to work well. Is the replacement of the shifter assembly truly necessary? I don't want to get stuck someday, but it is working fine now...
Any advice? I have no mechanical background.
Thanks for any advice!
http://www.unitedbimmer.com/forums/i...ies/thanks.gif
brian
colorado springs, co
Old 08-17-2007, 08:24 PM   #2
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
well it should work for a while but eventually it could get stuck, so if it isn't work the 600 to replace then don't.
Old 08-18-2007, 06:05 AM   #3
Rate My Car: 106 / 337
Do you know a reputable independent mechanic? They're usually cheaper than a BMW dealership as far as labor. For parts, www.pelicanparts.com sells replacement shifter parts for manual transmissions, you may want to call them to see if they have what you need for the steptronic . . they tend to have parts that are not listed in their online catalog.
E36 Clutch Replacement DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 23 12-05-2010 09:52 AM
Auto Shifter Arm/Knob Upgrade Rooz BMW OEM Parts Department DIY's & FAQ's 2 03-13-2008 09:01 PM
Double Shear Selector Rod? Rooz E46 5 09-21-2007 06:21 AM
shifter problem B_w. E36 3 06-06-2007 02:39 AM
Thinking about getting a short Shifter Rooz E46 11 01-17-2007 06:41 PM
