Old 08-12-2007, 07:10 PM   #1
ksmillig
Your Ride: 1999 328i
1999 328i - Please Help.
Hello All,
I just traded in the Volvo for the 1999 328i. It has miles on it and I had and "Inspection 2" done at the local BMW Dealership. This car has a host of issues. Automatic Trans.
1. The transmission "slips" under hard acceleration. And to day while driving the car easy I put on the cruise control at 70 mph, and I felt a "thump" and the yellow gear light with an "!" came on the instrument cluster. I immediately pulled over - turned the car off - let it rest - turned it back on the light was still on. I got home and did the same thing and the light didn't come back on.
1a. Under gentle acceleration there is no slippage (not going over 25/3000 rpm.
1b. The dealership says I'll need a new transmission =5k dollars. Ouch. The guy I worked with there said theres a place out in CA, Bavarian XXX that can get it done, or ship, for around 3k dollars.
2. Dealership said there's a hard fault in Airbag system (AB). And the LED in the dash won't come on. To me, this isn't a big deal.
3. Front window regulators noisy (as if they need some lubrication) can I DIY this?
4. Engine Valve cover gasket leaking oil.
5. The mechanic said that the front wheel bearing was noisy. There was a noticeable "voomp, voomp, voomp" . When the car was up on the lift, I noticed that the FL tire was nearly to the metal on the inside shoulder (JEEZ). I put on 3 new tires. The noise is gone.
5a. Think there's really a wheel bearing issue?
6. Control arm bushings worn. I can feel it in the St.Wheel when I brake hard or hit bumps. I can live with this for a while.
7. Rear axle seals leaking. No idea about this one.
8. And finally, the shifter plate doesn't light up when moved from "P". I could care less about this too.
Basically, I wish I still had my Volvo. I stick to my word though. I bought it, and I'm stuck with it.
I'm guess the Transmission issue is the biggest issue?
Please help.
Thank you all.
KSM
Old 08-12-2007, 07:22 PM   #2
Kasei
Kasei's Avatar
Your Ride: 1991 525i
Sounds like you got a slightly troubled bimmer....if it's worth it to you to invest in it then I would keep it and fix it up. I'll at least say that it was stand up of you to stick to your word, I'm not sure I would have done that unless most of those issues were disclosed to me prior to the purchase. Good luck, there are a lot of e36 owners on here that will be able to help you out and provide some DIYs.....Amanda...... Welcome to UB!
Old 08-12-2007, 08:00 PM   #3
Rate My Car: 106 / 337
Seriously? Dump the car and cut your losses. It's a bad way to start off, and that list won't be the end of it. Yes, a lot of it can be done with help from DIY's, but if you're fixing a car more than you're driving it, I'd say it's not worth sticking to your word. My opinion at least.
Old 08-12-2007, 08:44 PM   #4
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
I replied your PM, hope you get all that taken care of (if you decide to keep it)
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 08-12-2007, 09:46 PM   #5
Rate My Car: 183 / 337
for the tranny, you may just be low on fluid
1999 328i for sale ksleath Bmw Cars For Sale/Wanted 3 05-01-2007 11:03 AM
Selling '99 e46 328i Sports Pkg. xTheJokerx Bmw Cars For Sale/Wanted 7 01-16-2007 09:11 AM
1999 BMW 328i aley BMW General Discussion 10 05-27-2006 03:36 PM
BMW 328i Convertible for sale richacs Bmw Cars For Sale/Wanted 7 04-16-2006 03:33 PM
carfax pls! zenon United Off Topic  **FOR MEMBERS ONLY** 2 05-22-2005 02:37 PM
