Old 07-27-2007, 01:35 PM   #1
metalmukisha
metalmukisha's Avatar
Your Ride: E46 325ci 2004
Exclamation rumbling steering wheel
zup guys yesterday i took a long trip to the suburbs when i realized that my steering wheel rumbles when i brake well actually the whole car rumbles when braking so I dont know what the problem is... well for sure the brakes but what in the brakes??????????? thanx for the help!
Old 07-27-2007, 02:10 PM   #2
Rate My Car: 183 / 337
distorted rotors(again, thats for you dudesky) or maybe even(most likely not) your control arm bushings
Old 07-27-2007, 03:07 PM   #3
bill@bimmerclinic.com
bill@bimmerclinic.com's Avatar
Your Ride: Couple M3's
I would bet it's time for some new rotors & pads.
Old 08-12-2007, 06:38 PM   #4
ksmillig
Your Ride: 1999 328i
Control Arm bushings. You probably feel it when you brake hard, speed bumps, etc....
Old 08-12-2007, 06:50 PM   #5
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
Either you've got warped rotors or you Control Arms have a problem.
When my control arms went out I got a constant vibration through the steering wheel
Old 08-12-2007, 07:48 PM   #6
Rate My Car: 106 / 337
Originally Posted by xsperf
distorted rotors(again, thats for you dudesky) . .
Thanks, but RSF5 went and said it anyway
"metal"- I think you should do away with the speculation and get under there . . only one way to find out for sure what the culprit is. I would guess either control arm bushings or tie rod ends. Bad wheel bearings will do that too, but that would be more pronounced through the brake pedal.
Old 08-12-2007, 08:48 PM   #7
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
rotors and pads and I would also recommend a good alignment
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 08-18-2007, 12:21 PM   #8
metalmukisha
I checked today and I have to change the bushings, need new brake pads and brake discs allignment, also realized that the clutch disc needs to be replaced, i have no idea how much this is gonna cost....
Old 08-18-2007, 12:41 PM   #9
RSF5
RSF5's Avatar
Well are you going to DIY or have it done by a shop?
Old 08-26-2007, 06:58 AM   #10
kehani
Your Ride: 318i 2003
Wink Bushes
Change the lower control arm bushes there silver and 2 bolts,
warning they are pressed on and mechanic will ahve to do it.
Get someone to stand outside the car and put in R and Drive
with brakes one you will see wheel move a shocking amount.
Or Turn wheel 45 degrees and kick wheel it will move.
Put your head underneath while mate kicks tyre you will see
IT. About $600 labour and parts
Still no luck with E30 steering wheel Kel323i E21, E30 1 06-04-2007 08:50 PM
DIY: Add M3 steel guage rings to E36+ Remove Steering Wheel & Cluster. (pics) delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-09-2005 12:05 PM
STeering Wheel Upgrade! Best Sports Wheel for the E36!? (judge pictures) delmarco E36 37 09-12-2005 12:03 AM
steering wheel cruzin 323is E36 17 04-26-2005 06:18 PM
