Old 06-29-2007, 07:48 AM   #1
2003bmw325i
Your Ride: 2003 bmw 325i
16 to stock m3 18s??
hi. guys.
I got an advice changing my rims.
I have 03 325i with stock 16s(205/45/16) both on front and rear.
here is a question.
I just bought m3 stock 18 inch rims.
it comes with 225/45/18 front and 255/40/18 rear.
I am not sure about offset.
will those rims fit on my car?
I heard someone said I wouldn't have problems on fornt.
but the rear would be a problem.
is there any way that I can use these rear rims?
I would like to keep those tires that came with the rims since those are like new condition.
well, If I can keep those rims, needless to say, I will change tires.
I am not sure, so I couldn't even try yet.
my car only has premium package. not sports.
help me.
Old 06-29-2007, 03:32 PM   #2
bueras
bueras's Avatar
Your Ride: 2001 BMW 325ci
Got some advice for you. The front ones will fit fine, but the back ones are going to stick out a little so there is the risk that your rear tire will rub with the fender. There are number of ways to keep the tire from rubbing;
1. You rent a fender roller and roll your fenders which usually gives you about a 1/4 " clearance ($60 - $500)
2. You can buy some coil over springs to stiffen up your suspension so the wheel won't rub ($500 - $1000)
3. You can buy some spring spacers at Pep Boys to lift and stiffen up your suspension. They are like thick screws that tap into the gaps in the springs and give you from 3/4" to 1 1/4" lift. This is what I did for mine and its been working great ($10 for set of 4)
I hope that this helps, if you need more help feel free to send me a private message. Good Luck!
Old 06-30-2007, 04:46 AM   #3
2003bmw325i
THANKS bueras!!!
I have seen your post about that pep boys spring spacers!!
so my problem would be outer fender rubbing....got it!!!
Thanks alot!!!
I would go with #3!!
Thanks alot!! dude!~~
Old 06-30-2007, 09:13 AM   #4
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
^Roll the fenders.
stock 99 m3 convertible 99m convert E36 3 06-10-2007 06:26 PM
F/S: 95 stock M3 springs ///M Power Bmw Cars For Sale/Wanted 2 01-23-2006 09:01 PM
M3 SMG vs Mini Cooper S komodo BMW General Discussion 1 10-31-2005 11:18 AM
M3 mirrors or M3 spoiler DEATH2000 E36 10 07-23-2005 11:12 PM
History of the M3 komodo United Off Topic  **FOR MEMBERS ONLY** 9 06-05-2005 06:16 PM
