Installing stock navigation???????????
Does any one know if its possible to install the stock bmw navigation from a 05 m3 to a 01 325i?????? if its possible would anybody have any install instructions.......The items that i have are Display with flip down screen and cd player... the GPS antenna..the trunk mounted Nav unit..... No cables
anything is possible given then right tools, some ingenuity, and time... I would assume you will need all cabling for the unit (harnesses), but otherwise it should be a pretty straightforward install... I just moved so I have no idea where my software w/ wiring diagrams is... you can always check the ftp I have and d/l the wds (it's large... so it may take a bit of time) and look up the schematics.
| All times are GMT -5. The time now is 10:48 PM. |
