Old 06-18-2007, 03:29 PM   #1
SHE'S SWEET
SHE'S SWEET's Avatar
Your Ride: 1999 328I
replaced water pump????
hey all
is there anyway to tell if my waterpump has been replaced? i have been told that the water pumps on late e36/early e46 models have a tendency to go out, and i am going to replace it if it's not been done already.
Old 06-18-2007, 04:52 PM   #2
stevo
Your Ride: 1997 318se Touring
ok, firstly you could do a search using the "search " button at the top of this screen as there are a lot of threads on overheating and water pumps on this forum.
If you remove the water pump and it has plastic fins, it is the original pump.
Old 06-18-2007, 08:23 PM   #3
Rate My Car: 106 / 337
The water pump issue occured in the '92 to early '97 model years, so your '99 is in the clear. However, that of course doesn't rule out random failures, and keep in mind they should be replaced every 60k miles. Just for the record- outside of convincing documentation, there is no way to tell without removing the pump.
Old 06-18-2007, 10:05 PM   #4
metalmukisha
metalmukisha's Avatar
Your Ride: E46 325ci 2004
i had the same problem and it was replaced but i had to buy a new one, whats the problem anyway is it working? if not check if its burned or may be the fuse is burned if you want me to help u finding out whats wrong tell me the model and year of ur ride and ill send u some pics showing how to check ok... have a goodone bro
Old 06-18-2007, 11:56 PM   #5
Rate My Car: 183 / 337
a good way to check if its damaged is see if your car heats up very quickly to operating temperature, or see if gradually heats up
also, if you open your hood and see that your thermostat housing is aluminum/metal instead of a black plastic, most likely if that has been replaced, so has your water pump
Old 06-19-2007, 09:03 AM   #6
elsabor67
elsabor67's Avatar
Rate My Car: 33 / 337
Another way to check also is to open your Radiator cap and check to see if you have coolant returning into the reservoir tank. If you don't see any, your pump might be done for.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 06-19-2007, 09:57 AM   #7
i think the cap and the reservoir are all the same on the e36, no?
Old 06-19-2007, 11:08 AM   #8
elsabor67
elsabor67's Avatar
Damn "ingles sin barreras" that CRS kicking in again
Yes, they are together. But you should still see when you open the cap that squirt of coolant when the car is idling and when revving the engine.
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 06-19-2007, 01:39 PM   #9
ahh i see what you mean, interesting actually thats an excellent way to see if its working or not(or just in general you see when you open the cap if there is pressure in the system)
Old 06-19-2007, 01:44 PM   #10
. . all good, except by the time you check the cap and find out it's not squirting, it's already too late
Old 07-19-2007, 08:03 PM   #11
chizel
Your Ride: 2002
if it is the water pump, you may want to price compare for water pumps at ebay.com they have good prices on *buzz off* I had enough! other parts and accessories.
Old 07-19-2007, 08:53 PM   #12
^^^ban
Old 08-19-2007, 03:19 PM   #13
325myAZ
Your Ride: 2001 325i
Aside from pulling the pump, there's really no way to tell.
As a matter of maintenance (and concern) I replaced my pump, thermostat, belts and tensioners. It took a few hours and has given my piece of mind.
Depending on your mileage you might want to consider doing the same.
For what it's worth: My 2001 325 had a plastic impeller.
Old 09-20-2007, 09:51 PM   #14
eurocarman
Your Ride: 1987 325e
They still have issues beyond 1999, I just replaced a 2001 325i pump and it had a plastic impeller and was the original pump. The best repair is the Stewart pump http://www.stewartcomponents.com/ its a bunch a $$ but your done forever. The other thing is change the coolant every 2 years - use BMW coolant or Zerek G-05.
Old 09-21-2007, 05:13 AM   #15
I guess I stand corrected about the model years having a plastic impeller, good stuff to know
FS: e34 Auxilary Water Pump e39 bimmer Bmw Cars For Sale/Wanted 1 11-03-2011 12:36 PM
Advice on new DIY project... E30 M10 water pump mullethunter3 E36 16 12-13-2006 09:29 PM
water pump cabrit E36 2 02-28-2006 04:10 PM
Cheapest water pump price? Dudesky E36 7 08-02-2005 12:46 PM
