Old 05-22-2007, 05:56 PM   #1
DAM323I
Your Ride: E46 323I 1999
Cool rear passenger bearing help
Does anyone know how to change rear bearings passenger side 323i 99 and what special tool is used to take it off and put back on
Old 05-22-2007, 06:37 PM   #2
mzbmw325i
mzbmw325i's Avatar
you should have done a search in the forum and looked at the DYI's, unless you are very good at working on your car i read it's not recommended to do it at "home" , those bearings are PITA to take out, and you will need to purchase a special tool (if you want to make your life easier)that can run into 300$ or try and make your own home made "extractor" as some have done.
back to your question, there is plenty of articles and DYI's in the forum just use the search field for rear bearings, the procedure is no too different for most BMW's...I think.
Good Luck
P.S. taking it to a shop will run you couple hundred for each side.
Bav Auto has the tool ,$250+ choose your year model and pick tools, it should come up.
Old 05-22-2007, 09:15 PM   #3
DAM323I
thanks
ok i'll check it out but i might just it down by a qualified expert
E36 Rear trailing arm bushing replacement Dudesky BMW OEM Parts Department DIY's & FAQ's 19 06-01-2011 11:02 AM
DIY: Install Rear Shades on your E36/E46/E34 BMW! delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-26-2007 10:41 AM
DIY: E30 Front Wheel Bearing Replacement mullethunter3 BMW OEM Parts Department DIY's & FAQ's 13 02-18-2007 08:48 PM
DIY (please sticky):Blown Rear Shock Mounts!? E36 Tower Complete Replacment! delmarco BMW OEM Parts Department DIY's & FAQ's 9 08-27-2005 02:16 PM
E46 Audio Information - This is a god-send. EcianIce Car Audio and Electronics 4 04-21-2005 02:22 PM
