Old 05-04-2007, 08:08 AM   #1
spicytuna
Your Ride: '01 330ci MT
Question Tiny vibration when braking
OK, I know it's probably the rotor but my question is can I take it to any brake service station or is this something I should leave for the dealer?
330ci
Old 05-04-2007, 08:40 AM   #2
Rate My Car: 137 / 337
You might want to consider any GOOD BMW reputable shop or dealer. Most so called repair shops will mess up brakes or almost any BMW repair.
Old 05-04-2007, 09:18 AM   #3
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Hate to say it, but go to a dealer.
Old 05-04-2007, 09:51 AM   #4
Rate My Car: 106 / 337
+1 for the dealer- in case the problem is something else, you're better off at a BMW service center.
Old 05-04-2007, 10:36 AM   #5
3050rpm
3050rpm's Avatar
The problem may not be with the brakes/rotors, but could be with the ball joints, hence a more involved job. My advice is reputable independent shop first, then dealer, if you're uncertain as to the real cause.
Old 05-04-2007, 03:02 PM   #6
spicytuna
there's a local brake shop that will inspect it for free. Thanks for the suggestions everyone.
330ci
Old 05-17-2007, 11:36 PM   #7
anthon
Your Ride: bmw E31
3050rpm is right.... take it to a mechanic first and have it check. It could be the bmw ball joints culprit or other parts.
Old 05-18-2007, 12:24 AM   #8
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
1) Wheels not balanced. (missing weights)
2) When was your last alignment
3) Uneven rotors/break pads.
Check it out.
Old 05-19-2007, 08:43 AM   #9
Cuse330Ci
Rate My Car: 61 / 337
Your Ride: 2004 330Ci 6 spd
You may have an option besides the dealer. When I was in Georgia I was lucky enough to have a German mechanic named Dieter who worked on nothing but Bimmers and Benz's. He was BMW certified from Germany, super honest, and had fair prices. Look in the phone book and see if you see a place with a name like "Autobahn" or something super German and check it out.
Cuse330Ci
Vibration 45-65 MPH DropTopM M3 16 03-28-2011 02:51 PM
Wierd vibration at high speeds projal147 E36 24 07-24-2010 02:43 PM
Vibration when release the accelarator padel chhigo E21, E30 2 03-13-2007 11:35 PM
