Old 04-22-2007, 05:00 PM   #1
Vik
Vik's Avatar
Your Ride: 2000 323ci
Exclamation many problems
This morning my computer read this...
15 - Pre cat oxygen sensor response time cyl 4-6
76 - Throttle position sensor 1
83 - Drive by wire throttle control
84 - Drive by wire throttle control output stage
97 - Fuel injector cyl #5
C6 - Misfire fuel cut off cyl #3
EE - Misfire detected cyl #1
EF - Misfire detected cyl #2
E0 - Misfire detected cyl #3
E4 - Oxygen sensor adaptation limit cyl #1-3
E3 - Oxygen sensor adaptation limit cyl #4-6
any suggestions? I got the oxtgen sensors, I gotta change that, I changed the coils, my guess is I need to change the spark plugs, but I don't want to do that till i get my oxygen sensors and clean my injectors, or does tha not matter? Now how do I clean my injectors, or do I HAVE to buy new ones? And what is this Throttle position sensor? Drive by wire control and output gage? Im sorry I have never heard of that Should I call 911 I mean sounds to me like the car is dying
P.S. Could this be cuz i didn't change my oxygen sensors yet and keep driving the car so it causes more problems?
Old 04-22-2007, 06:11 PM   #2
nick_318is
nick_318is's Avatar
Title: Road Kill
Rate My Car: 4 / 245
The o2 sensor might be the problem. could be the TPS.
Old 04-22-2007, 06:19 PM   #3
Rate My Car: 81 / 245
No- the other way around. DO NOT change the O2 sensors until the other stuff is fixed. It's what caused the O2 sensors to go bad. If you replace them first, you'll end up damaging them again. Keep working the problems until all that is left is the O2 sensor codes, then replace them.
Old 04-23-2007, 12:04 AM   #4
ts03m3
Your Ride: '03 M3
Always find out what caused the O2 Sensor to fail and fix that before replacing the O2 Sensor itself. Especially with that list of codes something else is the primary failure.
Old 04-23-2007, 10:18 AM   #5
Vik
Vik's Avatar
Awesome, thank you what about those though
whats that all about? You think its the lack of spark and dirty injectors that could do that?
vB code is On
Overheating problems! Oh my! digismack E36 24 01-07-2007 12:05 AM
Common BMW problems FAQ Dudesky Site Feedback 2 09-07-2005 05:30 PM
so any common problems with the 330? Numark318i E46 6 07-03-2005 02:21 AM
