you do not need a kit to install the manifold but it makes it much easier and makes your engine compartment look stock. a shark injector will give you good gains with the manifold especially up top. if you think that you might get m3 cams hold off on the software until you get the cams.
Your Ride: 1998 m3 coupe :-D
i would assume one would need either a flahed ecu, (maybe the shark injector or maybe there is a version for the m50 manifold) to keep the stock engine computer happy or reprogramed ...looking at the size of the m50 manifold it seems like there is a lot more air comming in... turbodefrost i dont understand what you are saying! lol ill sell it to ya... for too much money though lol later guys
You dont need a kit, you could probably pick one up for 60 bucks from someone who just wnats to ditch it. Sharking your ecu is not necessary, but will improve performance.
