Your Ride: -95 320iA Touring
Time to change the head gasket or..?
Hi there.
I hope you can help me.
I have a few problems that I really need to get sorted out:
Coolant seems to disappear
When idling the the engine runs great for 2 sec. then a bit rough for 2 sec. and then back again,the same thing happens when revving it up
On both occasions the car shakes a little.
I do have white fumes from the exhaust when I'm revving and sometimes when I'm idling but but I have that on my other car as well that I don't have any coolant problem on that one.
The oil is changed and there's no indication of water in the oil.
When water runs low I loose the heating in the car.
I have tried bleeding it and air comes out from time to time
The car is a 320iA Touring -95 with 200000kms on the dial (124274 miles (I think))
SO.. Is it a blown headgasket or?
Why is the car shaking?
All and any comments are welcome.
I'd add a couple of bottles of "Bars Leaks" before blaming head gasket or cracked head. Bars Leak is a brand, not just a stop leak product and it's one of few that actually work.
Your description sounds like it could be a head gasket but try the above 1st.
The roughness problem could be related but it could also be vac leak, poor gas, moisture in gas, plugs, ICV - the list goes on. Need to know when last plug change, air filter, fuel filter,etc... to give you an idea of possibles.
Well.. the last oil and complete filterchange was done two weeks ago, sparkplugs I dont know.
What sparkplugs is recommended to the 6-cyl engine?
You'll have to check your owners manual or at the local parts store. Plugs vary by model year and I couldn't begin or attempt to perscribe a plug for your model.
And yes you can mix Bars Leak with just about any other stop leak - as I mentioned Bars Leak works - the others are pretty poor excuses for stop leak products.
You also might consider buying a DIY manual for your car.
Well.. I have Haynes but that is not very good. I've checked Bars Leaks and found out that there's a special one for headgaskets, but you have to flush the system first because it dont mix with coolant (the one i looked at).
Witch one of the different "Bars Leaks" products were you thinking of?
