Old 01-04-2007, 07:34 PM   #1
STROKER
STROKER's Avatar
Rate My Car: 261 / 337
Your Ride: 1992 325I
Question Just installed New Clutch PP & TB, Pedal goes to the FLOOR!
I just installed a new clutch pp and tb, I have not started the engine yet(i still have to but the intake back on) but after getting the transmission back in and everything else bolted back up I pushed down on the pedal to see how things felt.....and the pedal went to the floor , and stays there is this normal until I start the car back up????Man I hope I dont have to take the trans out again!!!! THAT WAS ROUGH!!!!!!!!
Old 01-04-2007, 07:45 PM   #2
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Do you have brake fluid in the car right now, the clutch works with the fluid from that. If not check into your master cylinder. Please also note that you should probably bleed the clutch and maybe your brakes if you have drained the fluid durring the process and most definitly if there isn't any fluid in there at the moment.
Old 01-04-2007, 07:52 PM   #3
STROKER
STROKER's Avatar
I didn't drain anything. I just lifted the car and removed everything. I did not remove the line or anything like that. It was working before. The reason I changed things is because the throw out bearing was bad. so i replaced everything else while I was in there
Old 01-04-2007, 08:14 PM   #4
Rate My Car: 183 / 337
its your master cylinder, it probably isnt connected to the fork in the tranny, if you take the master cylinder out and push the clutch pedal down, the master cylinder will extend the arm and the clutch pedal will stay to the floor. if you have no brake fluid and no pressur ein your system, the spring in the clutch will bring it back up, but your master cylinder isnt hitting the fork for whatever reason
Old 01-04-2007, 10:10 PM   #5
STROKER
STROKER's Avatar
I know when I put the Clutch master back in it was pushing back when I was bolting it up.. I will check it again in the morning...Man I hope I dont have to take the trans back out!!!! I have worked on alot of cars in my day...But changing a clutch on a BMW is NOT a walk in the Park!!!!!
Old 01-05-2007, 01:34 PM   #6
it will probably be your master cylinder then, and i dont believe you need to take out your tranny
oh and i know how you feel, when i did the clutch, i needed to take out the tranny 3 times after bolting it up COMPLETELY
turns out that the brand new clutch i had was warped.. haha wat an experience
Old 01-05-2007, 05:03 PM   #7
STROKER
STROKER's Avatar
I bled the Clutch Slave cyl.. It didn't help. So I took it off the trans and held it with the rod aginst the bottom of the car and had the wife push the clutch pedal. Again it went straight to the floor but the rod from the slave cylinder just bumped up an inch or less and went back down...So I am guessing I found the problem
Old 05-24-2007, 09:41 PM   #8
anthon
Your Ride: bmw E31
possible causes may be...brake fluid is very low, needs a bmw master cylinder replacement, air in the hydraulic system, large leak in brake hydraulic system.
Old 05-25-2007, 04:50 AM   #9
Rate My Car: 106 / 337
Weird . . that makes 3 of us here on the forum that did a clutch job at the same time. Not sure why you lost pressure in the first place, but keep pumping the clutch pedal. It'll build the pressure back up. It takes 10-20 strokes. If not, then you might have a 2nd look at the slave cylinder. But it's definitely in the clutch hydraulics- there'll be no reason to drop the tranny again.
Old 05-25-2007, 10:45 AM   #10
heh, this thread is kind of old, just someone took the liberty of being an absolutely amazing forum member, a model guy and actually troubled himself to GO AND FIND A LINK FOR A MASTER CYLINDER!!!
all this, of course, with no inent of advertising
Old 05-25-2007, 12:06 PM   #11
I didn't even see that
FAQ: How the clutch operates Dudesky BMW OEM Parts Department DIY's & FAQ's 10 07-09-2006 11:25 AM
Spongy? clutch pedal Dudesky E36 3 11-28-2005 05:37 PM
