Old 12-19-2006, 11:42 AM   #1
Mercenary(FH)
Mercenary(FH)'s Avatar
Rate My Car: 285 / 337
Your Ride: 1993 BMW 325is
RSM failure question Real quick
Ok so For christmas Im getting car stuff done. the RSM failure.....like how you need to replace the ....something to prevent it. some kinda bushing? what is it, and where can i order it from. Im gonan order it with the z3 reinforcement plates to jsut in case since their cheap.
also plus tie rod ends and lower control ARM (right one)
how much should that total out to be rough estimate?
Old 12-19-2006, 01:15 PM   #2
Mercenary(FH)
like just looking for what parts I'll need.
Im guessing rear Shock mount. rear subframe bushing, and RTAB
I just wanna do preventative maitinence for the RSM failure
and exactly where do the reinforcement z3 plates go?
does anyone have like a DIY or something.? or something
thx
Old 12-20-2006, 12:34 AM   #3
Linds
Linds's Avatar
Rate My Car: 68 / 337
Your Ride: 97 M3
The upgrade as far as OEM parts goes is (I believe) the Z3 reinforcement plates along with the e46 shock mounts. I went the easy way and got the RSM's from Rogue Engineering (no reinforcement plates needed). As far as installation, it's really easy. Just remove trunk carpeting, jack up the car, pull out the old shock mounts, throw the new ones on. The Rogue ones come with instructions and a diagram.
Old 12-20-2006, 11:07 AM   #4
Mercenary(FH)
e46 shock mounts u say? they fit perfectly?
and do the reinforcement plates go on top or bottom of the SM
Old 12-20-2006, 11:22 AM   #5
mrkbik
mrkbik's Avatar
Rate My Car: 125 / 337
Your Ride: '94 325is
I have heard great things about rogue RSMs. Also, here is a guide on how to install them- should tell you what order everything goes in.
Edit- link: http://www.pelicanparts.com/bmw/tech...ock-Mounts.htm
Thanks death.
Old 12-20-2006, 11:31 AM   #6
DEATH2000
DEATH2000's Avatar
Rate My Car: 116 / 337
^^ No link
Old 12-20-2006, 02:36 PM   #7
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
yea the e46 shock mounts should work you can even use them on e30s
Old 12-20-2006, 07:07 PM   #8
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
one of mine went out. You think it would work better then stock ones?
Old 12-22-2006, 11:48 AM   #9
Mercenary(FH)
gonna get the e46 mounts and reinforcement plates?
gonna elt local mechanic do it. I wonder how long it would take "hour wise"
Old 12-24-2006, 06:36 PM   #10
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
i think its the e46 m3 vert rsm's you want. just do it yourself instead of throwing money at that idiot mechanic you go to.
Old 12-25-2006, 11:02 PM   #11
Mercenary(FH)
the e46 ones are stronger too i think? tho
Old 12-27-2006, 11:39 PM   #12
catalyst
Rate My Car: 197 / 337
Your Ride: 1994 325is
the stock ones die instantly, youve got to do some kind of upgrade if you want them to last.
e46 ones are better, but there are alot of different options out there.
Quick Question about E46 spare tire celsdogg E46 10 01-14-2007 11:54 PM
RSM failure and Subframe failure 94bmw325i E36 22 10-25-2006 10:28 AM
can someone chop me a sig real quick? Chris Video and other Multimedia 14 10-04-2005 10:51 AM
Real quick, Weird people + Race bitcore Kill Stories 3 09-06-2005 05:43 AM
