Old 11-29-2006, 12:06 AM   #1
mincemeat
mincemeat's Avatar
Rate My Car: 217 / 337
Your Ride: E36 318i
Question (Hopefully) Basic electrical question
As soon as I turn the key to the accessories position, the system voltage plummets and within a minute there would not be enough charge to crank the car.
Visually inspected the battery and I realise it's well and truly dead - a slight bulge on its side.
So, tomorrow I'm doing the obvious and fitting a new battery...
However, what concerns me a little is that my car happen to have a Valeo altenator... what would the symptom of a faulty voltage regulator be? Would it cause a big enough spike to frag a battery like that?
Anyway here are some reference Test #9 voltages:
Running and idle: low 13's
Running and above 1500rpm: 13.7v - 14.1v
Engine off: Don't let it fall below 11v
Any comments would be appreciated, cheers
Old 11-29-2006, 12:10 AM   #2
Rate My Car: 84 / 337
More like just an old battery
Old 11-29-2006, 12:17 AM   #3
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
If that doesn't work, check the amp draw when the car is off. My car did that for a while and it killed a couple batteries. I fixed the problem though.
Old 11-29-2006, 04:57 AM   #4
Rate My Car: 137 / 337
Your alternator ratings are good, like "whitey" said it's just an old battery.
Old 11-30-2006, 04:41 AM   #5
mincemeat
mincemeat's Avatar
Your Ride: E36 318i
Thanks everyone for theiy comments.
The new battery went in and the guy used an electronic tester to check for drainage, which came out okay.
Now the funny thing was the age of the old battery. They deciphered the manufacturer's build code on it and concluded that it is barely over two years old and just out of warranty... strange.
Maybe I'm just very unlucky with that particular instance of a battery, or ya'll can start taking bets when this one blows up and why
Old 11-30-2006, 05:23 AM   #6
There's alot of variables in battery choices. Some places sell you "what fits" (physical size) other places sell what's made to operate in specific vehicles. You might have had a lower end version. A good rule of thumb - if you can afford it, buy the highest # of cold cranking amps. Don't skimp on battery quality for a couple of $$$ difference. Too many folks buy the least expensive and expect long life. The key here is to SHOP - $$$ vs CCAs.
IE: I shopped for my E34 and found one at Autozone that was 1000 CCAs and was only 69.95 where the "Die Hard" top end was $109 for 600 CCAs - so shop for your best value & buy from reputable sources.
Old 11-30-2006, 09:48 AM   #7
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
^^ Yep, always look for quality overall if you want long life.
electrical jybute E36 6 05-10-2010 02:14 PM
Airplane Flight Question komodo United Off Topic  **FOR MEMBERS ONLY** 105 07-27-2007 09:35 AM
Electrical Maintenance "101" c1apton BMW OEM Parts Department DIY's & FAQ's 5 11-30-2006 07:48 PM
Electrical Rumor dnhynz Z Series (Z3, Z4, Z8) 3 08-03-2006 03:22 PM
habbie, or someone. i've got a question EcianIce Lighting 32 06-09-2006 09:28 AM
