Purchase NEw Differential
Ok so im also looking into purchasing a New Diff ok well i just got under the car and looked to see that is was a 3.91 ? is there a upgraded version of this? or a better ratio for the e36 auto?
I'm assuming you want a higher rear end ratio for quicker acceleration. I think you'll have to go custom since a 3.9 gear was the highest used for E36 cars. Manual transmissions were available with a 2.93 (328i) 3.15 (325i) 3.23-3.43 (M3)..........etc. These are all lower and would make your car a dog off the line.
see if you can find a 4.1
so the lower the number the faster the accelleration?,
4.1 would be best ?> |
The higher the number (3.9+) the faster the acceleration. Lower numbers (2.93-3.15) will lower your rpms at speed and give you a higher top end mph.
yea i was just lookin on diffsonline and man they want a grip for a custom setup.
ok people here it is !
Optional Differential Gear Ratios Korman recommended optional gear change ratios for increased acceleration and acceptable RPM per mile: Model (E36) Stock Gear Ratio Recommended Ratio 318iS, Ti Manual Transmission 3.45 3.90 318iS, Ti, Automatic Trans 4.44 4.75 325 Manual Transmission 3.15 3.46 328 Manual Transmission 2.93 3.46 325/328 Automatic Transmission 3.91 4.27 M3 3.0 3.15 3.46 M3 3.2 , Auto and Lightweight 3.23 3.46 |
How much is it?
jeez im not sure but im sure its a pretty penny.
i dont think there is any point to getting a new diff with the auto. if you did a 5spd swap you would have crazy accelleration with the 3.91:drive2
yea i kinda figured that after these last couple of days of lookin up info etc.. , damn i hate myself for not buying a manual.:doh
TMS sells LSDs for around $2000
Metrix Racign and Metrix motorsport.
| All times are GMT -5. The time now is 09:58 AM. |
