Old 10-29-2006, 03:04 PM   #1
stubags99
Your Ride: 316i 1995
316 over heating problems
my car a 316i 95 model started to overheat so i called at a garage who then bled the system but car still overheated causeing the head gasket to blow so new gasket and head tested new rad and fan all so warter pump engine and hoses flushed thermostat replaced but still car overheats bad allso hoses red hot and preasure in them any 1 help out
Old 10-29-2006, 03:22 PM   #2
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
that post needs some periods, here take a couple: "......."
Old 10-29-2006, 04:40 PM   #3
Rate My Car: 84 / 337
I would look into upgrading the cooling system. A bigger radiator if it can fit for example
Old 10-29-2006, 05:24 PM   #4
stubags99
car has had brand new radiator fitted but still over heating
Old 10-29-2006, 05:37 PM   #5
Derek
Your Ride: 1993 325i
Check the fan clutch and ensure that it is not slipping.
Cheers Derek
Old 10-29-2006, 05:46 PM   #6
Rate My Car: 106 / 337
whatdoyoumeancantyouunderstandwhathessayingjeezlea rnhowtoread
Old 10-29-2006, 05:58 PM   #7
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
did u change the fan switch or temperature sensor in the block/cooling system?
Old 10-29-2006, 06:00 PM   #8
beem
Your Ride: '00 540/6 Dinan S2(sold), '90 525i/5, '01 Audi S4
dude. a 316??? Where in the world did you find one of those? No offense, but I didnt even know those could overheat....
Anyway, check the heater core unit as well. If you say that the water pump is replaced as well as other parts, flush, flush, and fush. Then bleed, bleed, and bleed. And then bleed some more. Most often, its air trapped that causes the most problems.
...let's go to the highway!
Member of the Spririted Driver Club.
Old 10-29-2006, 06:15 PM   #9
stubags99
the complete fan was changed radiator warter pump ect
grandparents want a car. craig United Off Topic  **FOR MEMBERS ONLY** 27 05-23-2006 11:47 PM
Rear heating vent jybute E12, E28, E34, E39, E60 3 10-15-2005 07:41 AM
Common BMW problems FAQ Dudesky Site Feedback 2 09-07-2005 04:30 PM
so any common problems with the 330? Numark318i E46 6 07-03-2005 01:21 AM
