Old 10-19-2006, 05:35 PM   #1
Cartony
Cartony's Avatar
Rate My Car: 82 / 337
Your Ride: 1994 318iC
Unhappy ticking injector? huh
I never knew injectors made noise . I have a ticking under my hood and a friend said it's the injector. Has anyone ever had this problem or noise. It's fricken annoying. I've searched for diy or something to tell me how to check for sure. Is it easy to change? Any help would be greatly appreciated before I put her to sleep for the winter. thanks
OO(llll)(llll)OO
Old 10-19-2006, 08:19 PM   #2
Rate My Car: 137 / 337
I highly doubt you'ld hear a ticking injector - you'ld get an erratic idle & drivabilty problems before you'ld hear it. I'd guess it's lifter noise, maybe timing chain, etc - especially since cooler/colder weather is more frequent. Try a good healthy oil change.
Old 10-19-2006, 09:03 PM   #3
Cartony
Cartony's Avatar
Figured you would respond."Master"
Just changed the oil like 800kms ago. So do you recommend taking off the valve cover and listening more closely?
OO(llll)(llll)OO
Old 10-20-2006, 03:52 AM   #4
nah, no master...lol, - just make note(s) when the noise is most evident -cold or hot, low or high RPMs, which side of motor noise is coming from, etc... You don't need to pull valve cover - you can use a chunk of heater hose or garden hose & use as a stethescope and listen by placing hose on different sections of motor, head, to narrow down where the actual "ticking" is coming from. A small exhaust leak can make a ticking noise, for that matter a sticking exhaust valve can cause a ticking noise (similar to header noise/tick) Also note what did you do to it last before noise became evident.
Keep me posted
Old 10-22-2006, 05:34 PM   #5
Cartony
Cartony's Avatar
Well i can't find my stethascope, but I did isolate it on the passanger side near the front. It starts after about 5 minutes of driving. Weird
OO(llll)(llll)OO
Old 10-22-2006, 05:43 PM   #6
I would guess it's just something simple like the timing chain tensioner needs adjusting. Especially after an oil change. (might have losen some gunk w/the fresh oil -part #s 17 & 18)
Old 10-23-2006, 08:11 AM   #7
Cartony
Cartony's Avatar
Thanks I'll check that out.
It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses - Elwood
OO(llll)(llll)OO
Old 10-23-2006, 11:03 AM   #8
You forgot Belusi's reply - "Hit It"
Old 10-24-2006, 09:34 PM   #9
Cartony
Cartony's Avatar
Which way do you suggest I turn the bolt, clockwise or counter?
OO(llll)(llll)OO
Old 10-25-2006, 02:45 AM   #10
Clockwise to add tension to it - small increments.
Old 10-25-2006, 09:39 AM   #11
215BIMMER535
215BIMMER535's Avatar
Rate My Car: 127 / 337
Your Ride: '97 328i
friend of mine with an E36 ///M3 had the same noise it seems like and a tension adjustment did the trick!
Old 11-02-2006, 08:29 AM   #12
Cartony
Cartony's Avatar
I was ready to adjust it and I thought, can I adjust it with the motor running or not, what do you think Master?
OO(llll)(llll)OO
Old 11-02-2006, 11:14 AM   #13
Cartony
Cartony's Avatar
Nope didn't work, I turned it a 1/4 and nothing. Could it be one lifter? Should I use thicker oil maybe?
OO(llll)(llll)OO
Old 11-02-2006, 07:10 PM   #14
What weight oil are you currently using and how many miles on car? Before you do any oil changing - you might try a small dose of Sea Foam or Rislone, or Marvel Oil supplements. These are detergent additives that might "un-gum" internals.
Old 11-06-2006, 03:46 PM   #15
Cartony
Cartony's Avatar
Hey I'm using 5w-30 with 195263 kms on it. I really don't trust additives.
OO(llll)(llll)OO
