emergency flashers
The emergency flashers are flashing and I cannot turn them off. Yesterday the crash sensor relay was replaced but after 100 miles the flashers came back on. I pulled the fuse to stop flashers (I could do without emergency flashers) and now I have no turnsignals. My wife was driving onetime ,when the flashers came on by themselves. When she hit a bump in the road they stopped, leading me to think a relay,loose wire, or a bad connection. I spoke to my service tech about disconnecting battery. He didn't know how this would work but at this time I am willing to try anything. If this works what about the next time the flashers malfunction?
check the switch and fuse connection.
Maybe the flasher unit needs to be replaced
From the Common Faults FAQ:
I am having a similar problem to this... I just got a 94 325is yesterday and the flashers have gone off a couple times...my dashboard lights up also though.. i need help too!
wait you dashboard lights up? like glows like a pumpkin?
The oil service/ispection light comes on, my ebrake light comes on, my brake fluid like comes on, everything "glows like a pumpkin."
still no answer to the problem that I haven't already tried. It's in the shop now . Ulie is checking it out.
emergency flashers
| All times are GMT -5. The time now is 08:05 PM. |
