Old 09-12-2006, 10:16 PM   #1
singring
Heated Seats Got Me Baffled !!
Since I bought my 1995 318i last year, only the backs of the front seats will heat up, with no temperature change on the seat bottoms. So, today, I checked for voltage at the connectors to the heat elements...all connectors say 12 volts. OK, then I checked for continuity from the heat elements themselves...now, I would expect to see that the circuit is closed for the heat elements for the seat backs( which work fine), and that the circuit is open for the heat elements for the seat bottoms( which don't work)....however, the ohmmeter reading for ALL elements is exactly the same, 6.3 ,so I checked the ohmmeter....probes apart, reading is 0.0...
probes together, reading constantly fluctuating....
What I don't understand, is that the continuity of the elements that work, and those that do not work, is the same, and since voltage is being fed to the elements connectors, then ALL the heat elements should be working.
Or, is there a fuse, or a fuse link, hidden somewhere, that may be blown and is not allowing the voltage to get to the seat bottom elements.
Everything else is working fine electrically, and mechanically, on this car, and I have checked the appropriate fuses, but all seem to be OK.
Any ideas ????
Thanks
Old 09-13-2006, 11:32 AM   #2
3050rpm
3050rpm's Avatar
I wish I could come up with a more definitive answer for you, but you might find something of relevance at www.geocities.com/itsmefilip/heated_seat.doc . Good luck.
Heated seats? Rooz M3 42 02-19-2006 04:10 PM
E36 Rear Tan Seats in new condition on sale for cheap! delmarco Bmw Cars For Sale/Wanted 6 08-27-2005 09:32 PM
A question about pre 1997 and post 1997 E36 seats! delmarco E36 4 08-20-2005 04:39 PM
FS: M3 Black Leather Heated/Motor Sports Seats jrhaile Bmw Cars For Sale/Wanted 7 06-07-2005 10:13 PM
E36 Seats Joey E21, E30 2 05-18-2005 12:16 PM
