Old 09-07-2006, 01:26 PM   #1
mrkbik
mrkbik's Avatar
Rate My Car: 125 / 337
Your Ride: '94 325is
Clicking sound during acceleration
Hey all, I have been noticing lately that when I accelerate from a stop, I hear a little clicking sound. When I let off the gas it stops. To me, this sounds like an exhaust-related problem, because the sound is coming from behind me, and is louder when I have the windows open. Has anyone experienced this before?
Old 09-07-2006, 06:32 PM   #2
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
maybe cats going bad
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 09-07-2006, 09:52 PM   #3
3050rpm
3050rpm's Avatar
Could be a heat shield or other piece of protective metal coming undone, not at all uncommon, generally benign. When I flushed my cooling system a few months back I found a loose piece of disconnected something-or-other, looked like some sort of bracket, nestled by the engine block. Best to get under the car and take a look at all the protective shielding, as well as any clamps that may have come undone, especially if attached to or supporting the exhaust. You may have to improvise a bit if you want to reattach or resecure any loose pieces, chances are the nuts or studs have snapped off.
Old 09-08-2006, 03:11 PM   #4
mrkbik
mrkbik's Avatar
Hmm, ok that sounds like it may be the problem. The last couple of days I haven't really noticed it, but I'll take a look at everything anyway.
Old 09-08-2006, 09:17 PM   #5
Rooz
Rooz's Avatar
Your Ride: 2003 M5
Old 09-09-2006, 11:35 AM   #6
mrkbik
mrkbik's Avatar
No, thank God. It sounds like a really faint clicking sound, and only when I accelerate.
Old 09-09-2006, 07:09 PM   #7
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
hmm could a bad vanos solenoid do that, or something of that sort? Are you able to make a soundclip?
Old 09-09-2006, 11:24 PM   #8
mrkbik
mrkbik's Avatar
I could, but I actually haven't been hearing it lately. It would also be hard because I would need to make a sound clip while driving and accelerating. I have also since heard a whistling sound coming from the engine, and concluded that it is the ICV. I bought a new one, and I am installing it tomorrow. Could the two be related in some way?
Old 09-15-2006, 05:54 AM   #9
Kiterunner
If its clicking, try checking the valve lifters. I experienced the sounds and upon checking, I found out that the valve lifters were faulty.
I was recommended to change them. My mileage is 135K. Recommend that you buy the originals...the OEM's will produce the clicking sounds after a few weeks. Goodluck..
Old 09-15-2006, 12:22 PM   #10
mrkbik
mrkbik's Avatar
Oh ok, I'll look into that.
Old 09-16-2006, 09:41 PM   #11
Mercenary(FH)
Mercenary(FH)'s Avatar
Rate My Car: 285 / 337
Your Ride: 1993 BMW 325is
how much are valve lifters and are they hard to install?
Old 09-21-2006, 07:01 AM   #12
Kiterunner
The valve lifters are approx USD 36 (I think). Since the one making the clicking sound cannot be distinguished, all 24 of them have to replaced. Takes about 2-3 hours. Also do check for some minitiare parts that are below the liftersm they may need to be changed too. GOOD LUCK.
Old 09-21-2006, 07:01 AM   #13
Kiterunner
USD 30 each...!!
Old 09-21-2006, 07:02 AM   #14
Kiterunner
sorry...usd 36 each
Old 09-21-2006, 08:06 AM   #15
defkon99
defkon99's Avatar
Rate My Car: 50 / 337
Your Ride: 1993 E36
OK well i thnk i can relate, does it sound somewhat louder at about 15-20 mph rolling>? and can you hear this click on turns coming from the back? anything over 20mph you cant hardly hear it?
If you you got a case of warn out bearings bud. That was my problem, but i do not suggest taking a look cause if they are bad as soon as you pop off the hub the bearings will fall out. But i can say try this test :
Lift the problem wheel and try pulling it back and forth there should not be any play between the wheel and the hub.
CLICKING SOUND fROM rear end ? WTF? defkon99 E36 34 10-18-2006 01:00 PM
Funky Sound comming from engine. doughboyea E46 32 09-12-2006 09:23 PM
Vanos sound zeaq328i E36 4 05-15-2006 07:50 AM
Weird sound! Need help! jrhaile E36 10 10-08-2005 04:53 PM
Sound Card Issues komodo Geek Chat 9 05-18-2005 10:11 PM
