Old 08-28-2006, 02:06 PM   #1
DEATH2000
DEATH2000's Avatar
Rate My Car: 116 / 337
Problem stalling
So i got a car was today then i went to visit a freind for a bit and i left the car parked in the sun and all. Then like 20 mins later i came back and tried to start the car and it keeps stalling and dieing when i start it. It was fine before i parked it but now it just wants to stall like its not getting any gas, it starts fine but it seems like it doesnt get gas and dies. Any ideas? Ive put enough money into it and i cant drop anymore, if this is an expensive fix i may be forced to sell it, something i thought id never have to do.
Old 08-28-2006, 02:13 PM   #2
Montizzle 325i
Your Ride: 1998 dakar ///M3 sedan 5-spd
maybe your wash soaked your DME. Its been known to happen on the e36. does it stay running if you give it gas and then die when you take your foot off the gas pedal?
Old 08-28-2006, 04:21 PM   #3
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
yeah that could be the problem, I would start with that. Then try fuel related problems.
Old 08-28-2006, 05:29 PM   #4
Rate My Car: 183 / 337
if you give it gas, does it still stall? if yes, then it may be ur TPS(but likely not)
Old 08-29-2006, 12:39 AM   #5
DEATH2000
DEATH2000's Avatar
Yup, i can drive it as long as it gets gas, if i dont keep my foot in the pedal it dies. How bad is it if i did soak it? Cause ive taken it through that car wahs like 20+ times and nothing has ever happend.
Old 08-29-2006, 04:24 AM   #6
Rate My Car: 106 / 337
The 'flooded DME' issue was resolved after MY '95, so it's definitely not that. xsperf may be on to something tho . . could be the ICV or TPS. You could have gotten water or moisture into the ICV or its lines, which in turn can cause your TPS to behave erratically. If that's the case, just clean it and dry it out, and you should be good to go. Also try and see it the car has any fault codes stored.
Old 08-29-2006, 09:43 AM   #7
DEATH2000
DEATH2000's Avatar
Ok were is the ICV so i can do that?
Old 08-29-2006, 10:00 AM   #8
yep, more than likely the ICV, actually, the ICV is really a pain to reach, its under the intake manifold, you have to look at a very careful angle to spot it, you wont be able to spot it easily, however if you look at a DIY for it you should be able to take it out and clean it
Old 08-29-2006, 12:13 PM   #9
DEATH2000
DEATH2000's Avatar
Well good news for me, its not the ICV as far i know. Theres a tear in the little rubber boot right by the MAF on the intake, tis a $50 part so im happy.
Old 08-29-2006, 12:15 PM   #10
Rate My Car: 137 / 337
That is commonly known as a VACUUM LEAK... lol (glad you found it was easy fix)
E36 : anyone had this problem? akinthecat E36 6 09-28-2007 04:35 PM
MAJOR PROBLEM - Starting Car!!!! HELP!!! projal147 E36 12 09-07-2006 11:18 AM
odd lighting problem white E21, E30 8 07-21-2006 04:19 PM
