Old 08-24-2006, 06:24 PM   #1
3050rpm
3050rpm's Avatar
Bushings and Mounts
I would appreciate people's advice and experience concerning suspension and steering bushings, engine and transmission mounts. My car is a '95 (bought new) with a 5-speed, driving style is gentle to moderate (I do enjoy leaving obnoxious SUV drivers on the verge of tipping over as I apply a few lateral g's to outdistance them on the highway on-ramps, though). My rear shock mounts are fine, and I believe (my third set of) the notorious ball joints are okay as well (I am now at 203,000+ miles). While underneath changing the differential and transmission fluids the other day I noticed much to my surprise that the transmission mounts looked quite good, no visibile cracks or deterioration.
But, what of other items? I have not encountered in my searches much if any discussion of engine mounts, but I assume they go the way of all flesh, errr, rubber. Is that a DIY job? If so, anyone know of a write up?
Rear trailing arm bushings? I have come across discussion of them, and as the rear tires are showing inner edge wear, I suspect those bushings may have something to do with it (time for new sneakers anyway).
Are there other bushings, mounts, rubber components one should check or replace on an 11+ year old car?
Thanks.
Old 08-24-2006, 08:05 PM   #2
Rate My Car: 106 / 337
Old 08-27-2006, 08:28 AM   #3
3050rpm
3050rpm's Avatar
Thanks for that (he said rather sheepishly, as he had completely overlooked the Knowledge Base link before making the post). I gather engine mounts don't pose much an issue, judging by the volumes of responses?
Old 08-27-2006, 09:16 AM   #4
Rate My Car: 137 / 337
Engine mounts are pretty reliable and may sag with age. Trans mounts are another story - they are overlooked and wear slowly and then things like guibo joints & strange acceleration vibes start popping up.
Old 08-27-2006, 12:01 PM   #5
3050rpm
3050rpm's Avatar
Thank you for that, another couple of areas I should give a good look over. Am I the only one who thinks of the scene where Sonny Corleone got rubbed out in "The Godfather" whenever he hears the word "guibo"?
Old 08-27-2006, 12:45 PM   #6
Sonny was a "GUIDO" not a guiBo...
Old 08-27-2006, 02:55 PM   #7
3050rpm
3050rpm's Avatar
Well, I was close...
Part # School c1apton BMW OEM Parts Department DIY's & FAQ's 10 09-01-2010 09:50 AM
Bent something hard..... DEATH2000 E36 17 03-10-2006 09:49 PM
Strut tower bars DEATH2000 E36 21 01-05-2006 10:12 PM
JT-Designs Rear Shock Mounts GB Special Jon@MPerformance Bmw Cars For Sale/Wanted 4 05-03-2005 01:44 PM
