Old 08-11-2006, 01:52 AM   #1
Chevell
Chevell's Avatar
Your Ride: 1996 328i
Need Condenser/Aux Fan
Anyone have an auxilliary fan they want to part with? Cheapest I found was $99 on ebay. Looking for something cheaper. My clutch is also going bad so i want to do the Fan Delete Mod at the same time.
Alternatively, anyone try putting in a third party electric fan to replace the aux fan?
Chevell
1996 BWM 328i
http://www.chevell.net
Old 08-11-2006, 06:24 AM   #2
Rate My Car: 106 / 337
It's been done before, although I don't have details. Lightweight and clutchless, as long as it's no heavier than the OEM unit, so you don't increase engine load & parasitic drag. It also should fit the fan shroud as close as possible, since its main job is to pull cool air through the radiator.
On the aux fan, I doubt you'll get them any cheaper. Myabe you could try a used one from Bav Recycling:
http://www.bmrparts.com
Old 08-11-2006, 08:03 PM   #3
Alpine328i
I have a question... I just had to replace my fan and it was like $30 something bucks from a dealership... which fan are you doing? I thought mine was called th aux fan.... the one on the engine right? Or are you talking about the one right behind the grilles in the front?
---Bailey
"In the road of life there are Bimmers and there are Bimmers"
Mods: Full JDM lighting, APC bulbs, ///M rims, Four wheel Brembo rotors, Bilstein Touring suspension.
Old 08-11-2006, 08:48 PM   #4
Chevell
Chevell's Avatar
the electric fan in front of the condenser. You had your mechanical fan replaced. I'm deleting that and replacing with a second electric fan.
Chevell
1996 BWM 328i
Old 08-17-2006, 08:12 PM   #5
Alpine328i
What does that do, just out of curiosity?
I keep hearing "fan delete mod" and I have no idea what it is....
Pardon the newb....
---Bailey
Old 08-19-2006, 06:48 PM   #6
Alpine328i
Anyone? Anyone? Bueller? Bueller?
---Bailey
Old 08-22-2006, 02:23 AM   #7
Spieluhr
Title: ///M Driven
the fan delete mod is where you remove the engine fan, replace the thermostat and aux. fan switch with lower temp. units, and put water wetter in your car. what this does is by removing the fan you get rid of the parasitic drag of the fan, so your engine revs easier, and produces more power, and the new thermostat, aux. fan switch, and water wetter ensure that despite the loss of fan, your engine does not over heat.
go to www.bimmerworld.com for the kit, i think it's liek $50-60.
Old 08-22-2006, 04:26 AM   #8
^^^You forgot the most important part: the fan blades are notorious for breaking off & shattering, taking out everything else along with it- water pump, hoses, radiator. Hence, no fan = no cooling system damage
Old 08-22-2006, 12:40 PM   #9
Alpine328i
So this isnt a very smart mod then, huh? If it's notorious for breaking, I mean... that doesnt make much sense to me.....
Thought?
---Bailey
Old 08-22-2006, 03:49 PM   #10
^^^You're reading this wrong. The fan delete mod consists of removing the fan, because it tends to break, and also because of all the reasons Spieluhr mentioned.
Old 08-23-2006, 12:55 PM   #11
Alpine328i
OOOOOOOOOOOOH..... yes, I read it COMPLETELY wrong.....
So this sounds cool.... I just replaced my fan, A/C belt, water pump, thermostat about a month ago though, so I'm not taking it all out!! HAHA
Thanks DSKY!
---Bailey
Fan problems kenric E46 4 06-18-2006 08:51 AM
Heater Fan Switch Not Working? c1apton BMW General Discussion 4 12-14-2005 01:49 PM
Opinions on fan delete. catalyst E36 20 09-20-2005 03:22 PM
Opinions of Fan Delete ///95M3 E36 10 06-02-2005 08:47 PM
fan whine Spieluhr E36 5 05-17-2005 09:30 PM
