Old 08-02-2006, 07:05 AM   #1
akinthecat
Your Ride: 1999 320i
Microfilter replacement
there's this excellent article bout changing the microfilter ([url]www.pelicanparts.com) I was wondering how can you tell if your microfilter needs changing. the air flow from the a/c ducts seems not too strong. Can i clean the air filter and reuse it?
Old 08-02-2006, 07:25 AM   #2
Yatti
Yatti's Avatar
Your Ride: 2003 540I Sedan (M-Sport)
isnt there a cetain mileage point for filter replacement?
jaredgray-AT-acanac-DOT-net
PEACE
My Himachi Server Is=
Old 08-02-2006, 08:13 AM   #3
Linds
Linds's Avatar
Rate My Car: 68 / 337
Your Ride: 97 M3
If your air flow seems restricted than you probably need to change it. You really won't know until you pull it out and look at it. I haven't heard of anyone cleaning and reusing them. It'll probably be $20, definitely not more than $30. If you have AAA you can get a discount on the part from NAPA.
Old 08-08-2006, 08:52 AM   #4
akinthecat
thanks!! i changed the microfilter myself after getting an oem filter from the agent. The funny thing is that i followed the instructions that mentioned my filter was on the passenger side. In fact it was behind the center console after removing the panel on the driver's side of my car. It took me 15minutes to change it and get it all cleaned up in there. I spent another hour to put back all the panels and vacuum the other side of the car. Guess that was the first time the panel was removed coz i saw a whole bunch of loose sticky cloth that was holding up the wires. I tidied it up a bit by securing all those wires with new cable ties and discarded a handful of sticky black cloth from under there. Btw, the old microfilter was covered in soot, cathairs and all sorts of grunge. Popped in the new one and now the a/c is working so well and cool.
After starting up the car, i noticed that the ABS and the traction control lamp lit up. I ignored it since normally it would go off when i switched off the car and turned her on again. but it has been 3 days and the abs and traction lamp is still on. Can't feel any difference though. Was there something i did wrong when i was under the panel and 'tidied' her up? Didn't disconnect anything.. any ideas? IS there a way to reset these lights?
Spark plug replacement & compression test DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 21 10-18-2010 10:22 PM
Drivers front strut replacement DEATH2000 E36 14 08-19-2006 06:43 PM
325xi front wheel bearing replacement LynnFlores M3 5 04-07-2006 04:47 PM
Replace your Microfilter! Spieluhr E36 16 12-23-2005 06:09 PM
O2 Sensor replacement Fadec40 E36 15 05-27-2005 08:09 PM
