Old 08-02-2006, 12:10 AM   #1
SHAHAB323IS
SHAHAB323IS's Avatar
Title: Professional Noob
Your Ride: 1998 323is
Electrically F*cked
I need some MAJOR help
i'm just going to get right into it
earlier today i hardwired a valentine one into my buddie's e46, used a brown ground wire and green and blue power wire from the universal transmitter pre-wire, to attach the v1, worked perfectly
i had already planned to wrap my selector rod with solder for a cheap weighted selector rod as detailed on understeer.com
here:
http://www.understeer.com/cheapwsr.shtml
so i figure what the heck might as well do my valentine one as well, since i already had a project planned
get home
first thing i do is try connecting the v1 to the sunroof switch via black/yellow wire which i believe to be power, and brown ground wire
when i turned on the valetine, the sunroof opened
i'm thinking in my haste i tapped the wires after the switch not before
basically then the sunroof wouldn't close or do anything, it seemed like it was dead, so i get my allen wrench out and close the sunroof manually
then i think oh well i'll take that into work(bmw dealership) tommorow and figure it out probably not a big deal
so then i searched google got a thread from bimmerforums that said use the purple and white hote wire from map/dome light assembly and brown ground wire
so i try that with the wire tap crimp connections
still nothing
after i tried that the map/dome lights don't work
i figure ok done with that do the selector rod
so i do the selector rod
put the car back down
i go to start the car, car starts and immediately dies, basically my life is over is what i'm thinking lol, icv stuck closed? who knows, maybe it's not getting power because of all the electrical problems,
the engine will stay on if i keep the gas pressed in
but as soon as i take my foot of the gas it dies
also during this whole dieing situation, obc read tailight failure, and the driver's side taillight and parking light weren't working, but the turn signal was
then i checked windows they don't work either, and niether do the vanity lights? above the sun visors
so here's where i'm at now:
1)engine turns on, dies immediately, will stay on however if i stay on the gas
(i'm assuming icv isn't getting power with the elctrical mishaps, just assuming)
2)sunroof doesn't move at all
3)windows don't move
4)driver side tail light out
5)driver side parking light won't come on
6)vanity lights out
7)map/dome light out
basically if all else fails i'll have to tow it to my work and hope my boss can hook me up, doubt it though, but i'm definitely going to talk to someone at work tommorow
basically i need help, i rushed something, and continued to rush things, until i thouroughly screwed myself over, and well just looking for any help at all
thanks in advance
Old 08-02-2006, 03:34 AM   #2
Rate My Car: 137 / 337
Without seeing it, I'm guessing you loosened a ground source that handles a major amount of ground connections or created a short accross a ground bundle by the amount of electrical issues you're having at one time. Go back and reconnect all the wires you tapped into and check nearby for an "un-intentional" cut...
Old 08-02-2006, 10:19 AM   #3
SHAHAB323IS
the first thing was remove what i added, none of the wires i tapped into were cut or severed at all, they're wholey intact and no fuses were blown
Old 08-02-2006, 12:52 PM   #4
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
damn, if everything is reconnected... you could have a short somewhere else maybe?
Old 08-02-2006, 02:33 PM   #5
Rate My Car: 183 / 337
how about relays, like the DME relay? i dont think you have 1 million problems, just 1 problem(or 2) that will fix everything
Old 08-02-2006, 04:49 PM   #6
SHAHAB323IS
well apparently 2a.m. in a dimmly lit garage when you're exhausted and upset isn't a good time or place to check for blown fuses, because i checked the fuses last night multiple times and didn't see anything wrong, got it into the sunlight today, saw 3 clearly blown fuses, switched em out, everything works fine, just have to figure out how to CORRECTLY hardwire a v1 to an e36 now
thanks to everyone for the help
Old 08-02-2006, 05:10 PM   #7
wow, glad u got that straightened out, im sure it felt like crap to have though u totally screwed up your car...
Old 08-02-2006, 06:27 PM   #8
RealBmw 02
Title: GRIP > DRIFT
Rate My Car: 78 / 337
Fuses would have been the first place I checked. Good thing you found them before too much headache
1970 BMW 2002
Driven by skill, not money
Old 08-02-2006, 07:52 PM   #9
SHAHAB323IS
yeah i did feel like crap, i thought i was royally screwed, i did check the fuses first, it was dark, i couldn't tell that any were blown, i honestly sat and stared at my fuse box multiple times last night, i don't know how i missed them
p.s. i got the v1 hardiwired and working now too, i'm happy =]
Old 08-02-2006, 10:00 PM   #10
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Happy to hear you got it at 1st I thought fuses too, I know that feeling when its not working and all you can think is FUCK I really Fucked up only to later realize its a simple problem.
