Old 07-28-2006, 12:19 PM   #1
catalyst
Rate My Car: 197 / 337
Your Ride: 1994 325is
stalling m50..
Doesnt want to start (takes many many trys) and it will stall if not given gas..
i cant figure it out.. i thought it might be a vaccum leak but ive checked everything and cant find any leaks.
im going to clean the icv in a sec, but i dont think thats the problem.
Old 07-28-2006, 12:29 PM   #2
Rate My Car: 106 / 337
No fault codes? Getting fuel pressure? How about the throttle position sensor? Hmmm, what else . . think how hot it is today, and the humidity, maybe that'll give ya more ideas . .
Old 07-28-2006, 03:59 PM   #3
Rate My Car: 183 / 337
as far as im concerned, TPS sensor would let it start, and he says that it wont start unless given gas, meaning that the TPS sensor does work(if the engine will rev up it works), im thinking just like you said, something with fuel pressure, are your fuel lines clogged, fuel pump, and i dont think its the injectors b/c that would mean that all 6 of them got dirty/clogged at the same exact time
Old 07-28-2006, 09:54 PM   #4
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
dirty fuel filter, or maybe fuel pump relay?
Old 07-30-2006, 02:41 PM   #5
catalyst
fuel pump wasnt getting power, threw a new relay on from my wrecked 325, still no power going to the pump..
battery is connected fine, i bypassed the relay and the pump ran fine so it is not a bad fuel pump..
wtf is going on...
Old 07-30-2006, 03:54 PM   #6
you say you shorted the relay and the fuel pump worked, and you replaced the relay and that didtn work, well its probably the wire that goes to your relay that supplies the 12V when the key is in the ignition , if i were you, i would look up the wiring diagram for your car(manualsunlimited.com is a good place) and trace that wire back, see if its cut
Old 07-30-2006, 04:11 PM   #7
catalyst
yea most likely, thing that is not making sense is that the car wouldnt start even when i heard fuel spraying inside the engine and heard the pump going..
i need this fucking car running by tomorrow!!
Old 07-30-2006, 04:13 PM   #8
are you sure its not another problem, other than fuel?
Old 07-30-2006, 04:15 PM   #9
catalyst
well since the pump was not running before and when i shorted it, it ran, im assuming that it is fuel related.
i did pull a spark plug to check for spark but im not sure if i checked correctly.. i could not get it to spark but im not sure if it was seated in the coil pack all the way.
Old 07-30-2006, 05:24 PM   #10
Rate My Car: 137 / 337
Check the fuses for fuel pump and assorted relays. Dudesky did a post awhile ago that listed 3 fuses related to fuel pump. (might try to IM Dudesky)
Old 07-30-2006, 09:01 PM   #11
Old 07-31-2006, 08:18 AM   #12
catalyst
Originally Posted by Dudesky
thanks.
Only thing i didnt check was the DME relay.. that may be it.
Old 08-01-2006, 03:14 PM   #13
catalyst
Still no luck with replacing both the dme and fuel pump relays, is there any chance it could possibly be the relay sockets themselves?
i hate throwing parts at a car.
Old 08-02-2006, 05:18 AM   #14
In case you don't have a Bentley:
I seriously doubt it's the wiring at the back end of the sockets; not much can go wrong there. More likely you'll have to trace back further beyond them. You checked for constant voltage (12v) at pin 30 on both the DME & fuel pump relay sockets, right? I'm starting to think it isn't fuel related.
Old 08-02-2006, 02:38 PM   #15
dudesky, should he have constant 12V voltage, or is it only when he puts the key in? sorry but ive dealt with so many cars w/electrical problems and recently that was the problem, either the wire is cut, or corroded or something
M50 Manifold Installed (Pics) komodo E36 35 05-04-2011 12:29 PM
buy m3 cams for my M50 ? defkon99 E36 7 07-25-2006 09:16 AM
M50 Throttle Body xsperf Bmw Cars For Sale/Wanted 0 10-10-2005 12:04 PM
M50 Manifold komodo E36 43 05-22-2005 07:31 PM
m50 manifold (i have given in once more :( BaLAnCe17 E36 24 05-15-2005 02:27 PM
