Old 07-27-2006, 11:31 AM   #1
DEATH2000
DEATH2000's Avatar
Rate My Car: 116 / 337
Drivers front strut replacement
Well i had my car in for an alignment then it started pulling again so i took it back cause i knew it shouldnt be doing that and in the inspection report they said they checked the suspension out and it was ok. Well i took it back and they had another look, and they were able to determine the front strut was "leaking" is what they told me and thus needed replacement. I dunno much about the part so can somone confirm the validity of this claim? Also since im lowering the car i should replace all 4, but would it be ok just to replace the front ones since im low in cash? Thanks
Old 07-27-2006, 11:56 AM   #2
defkon99
defkon99's Avatar
Rate My Car: 50 / 337
Your Ride: 1993 E36
Yup its happens allright! well the front is goin to be more expensive than the back just so u know, but doing 2 at a time wouldnt hurt.
Old 07-27-2006, 01:02 PM   #3
EuroStyle
Your Ride: 92 325i
It is ok to replace just the two front struts, but you should never mix gas and automatic shocks (ie stock rear shocks w/ Bilstein Sport or Koni SA struts)
If you plan on lowering the car I would just bite the bullet and do it all now. It will end up saving you money in the long run.
-Matt
Old 07-27-2006, 03:10 PM   #4
Rate My Car: 137 / 337
Just make sure if you're replacing struts (& springs later) that the new struts are compatable with your future spring set-up.
Old 07-27-2006, 08:40 PM   #5
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
Do it at all at once man, thats what I ended up doing when my front struts were done.
Old 07-28-2006, 11:13 PM   #6
Alpine328i
Well, I guess, TECHNICALLY SPEAKING you could mix "gas and automatic shocks" as EuroStyle has previously mentioned. For instance, I have two Bilstein Touring struts on order from bavauto (see my previous post in the E36 forum on this topic).
If you're light on the loot, just get two for the front and do the rears later.
Well, that's my opinions... I'm sure I'll get shit for it, lol...
---Bailey
"In the road of life there are Bimmers and there are Bimmers"
Mods: Full JDM lighting, APC bulbs, ///M rims, Four wheel Brembo rotors, Bilstein Touring suspension.
Old 07-29-2006, 08:10 PM   #7
DEATH2000
DEATH2000's Avatar
Ok that helps, but what i asked is im loweing the car with Koni springs and shocks all around, and what i needed to knof if its ok just to replace the front two struts rather then all 4?
Old 07-30-2006, 09:22 AM   #8
Rate My Car: 106 / 337
Yes, you'll be fine. You can do the fronts first, then the rears, just don't drive crazy or anything like that before you complete the job, because your springs won't be matched. Be prepared for unusual handling behavior, but it shouldn't be too bad at all. If you ask me, you really should wait till you get everything and then do it all at once . . depending on how much time you need to get up the cash, you can probably "baby" that blown strut till then by taking it easy on the car. When I bought my car, it had both fronts blown and leaking. I ran on those for a good 3-4mo before replacing everything.
Old 07-30-2006, 09:42 AM   #9
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Bilstein Sports FTW!
Old 07-31-2006, 01:54 PM   #10
DEATH2000
DEATH2000's Avatar
Ok good to know thanks. I make good money were i work (pub) so i can save the money easily within a month. I just had other shit i was planning to spend my money on first. So this comes as a kick in the balls to my bank account. Im getting a set of Koni springs and shocks.
Old 08-17-2006, 08:17 PM   #11
Alpine328i
So, I'm doing my bilsteins this Sunday (front only) and I have the OEM rears on there for now... what kind of "unusual handling" should I expect? I dont understand why this would make a difference.....
Thanks in advance....
---Bailey
Old 08-19-2006, 05:23 AM   #12
^^^ I said that because Death was doing his springs at the same time. That would mean his springs would be changed along with the front struts first, then the rear springs and shocks sometime later. Because of the different springs during the interim between front & rear, he might experience some weird handling. But you will be okay if you're just changing the struts.
Old 08-19-2006, 08:56 AM   #13
Alpine328i
Cool man, thanks!
---Bailey
Old 08-19-2006, 02:06 PM   #14
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
yeha actually e36 blown suspension is still alright, I mean I drove with mine for at least 2-3 weeks, and it still handled pretty well. Probably could have had it for a lot longer.
Old 08-19-2006, 06:43 PM   #15
Alpine328i
So I put on my Bilstein Tourings today. I was going to do it tomorrow, but it's supposed to rain like a mofo.
And I'm sorry to say that I'm not impressed. It's not that I dont like them, it's just I thought it would change the handling a little more. To be honest, I dont feel like it made any difference at all.
Um. yeah.. that's pretty much all I have to say about that. So if you're looking for an "upgrade", dont buy these. If you're looking just for an OEM replacement, then do it up, these are your struts.
--Bailey
(yes, I know this is a duplicate post on two threads, but I thought it to be relevant to both conversations)
---Bailey
FS: Dinan Front Tower Strut Bar komodo Bmw Cars For Sale/Wanted 13 08-13-2006 02:26 PM
325xi front wheel bearing replacement LynnFlores M3 5 04-07-2006 04:47 PM
Physic savants! Rooz Geek Chat 2 09-17-2005 06:22 AM
MPerformance May Special on JT-Designs Front Strut Bar Jon@MPerformance Bmw Cars For Sale/Wanted 6 06-12-2005 04:36 PM
E46 Audio Information - This is a god-send. EcianIce Car Audio and Electronics 4 04-21-2005 02:22 PM
