Old 07-27-2006, 10:57 AM   #1
singring
Rear Coil Measurement 318i
Had some brake work done on my 1995 318i last week, and the technician found the rear driver's-side coil was broken at the bottom of the coil. I left the coil as is, so I could research this out. So yesterday, got out my Bentley, and did a measurement from bottom of wheel rim to edge of wheel-well. ..
did this for both sides....oddly enough, the measurement on the passenger side (532mm) was LESS that the driver's side (535mm), yet there is a very slight listing (lower) on the driver's side when viewed from the rear. All measurements were done with the car empty, no suggested weights as noted in the Bentley manual.
The coil on the passenger side is good. I'm baffled. since the coil is broken on the driver's side, shouldn't the measurement be LESS than the passenger side?
thanks in advance, for the advice
E36 Rear trailing arm bushing replacement Dudesky BMW OEM Parts Department DIY's & FAQ's 19 06-01-2011 11:02 AM
BAv-Auto Performance Coil Install. defkon99 BMW OEM Parts Department DIY's & FAQ's 14 05-10-2009 11:23 AM
DIY: Install Rear Shades on your E36/E46/E34 BMW! delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-26-2007 10:41 AM
DIY (please sticky):Blown Rear Shock Mounts!? E36 Tower Complete Replacment! delmarco BMW OEM Parts Department DIY's & FAQ's 9 08-27-2005 02:16 PM
E46 Audio Information - This is a god-send. EcianIce Car Audio and Electronics 4 04-21-2005 02:22 PM
