Old 07-14-2006, 08:06 PM   #1
CAPiTUL
CAPiTUL's Avatar
Your Ride: 98 328i
Check Code Light
Brake Lighting System/Circuit or something to that effect. What does that usually indicate? Besides the obvious that something is wrong with the brake lighting system/circuit. Suggestions?
Also, what about an occassional 3 beeps from the front left vent area?
Arigatouuuuuuuu.
When I was a kid, we had the Atari 2600 with games like Space Invaders and Asteroids! There were no multiple levels or screens, it was just one screen forever! And you could never win. The game just kept getting harder and harder and faster and faster until you died! .... Just like LIFE!
http://www.aftermarketcity.net/forum/
The BEST online directory for your car needs!
ユナイテドビーマーはいいですよ!
Old 07-14-2006, 08:10 PM   #2
Rate My Car: 137 / 337
Have you checked to see if you have a brake light out? Also please post the ACTUAL read out you get, it would help us greatly who are trying to help you.
Old 07-14-2006, 08:19 PM   #3
Chris
Chris's Avatar
Title: Visiting Mod
If it went out next time you turned it on, it went away, it was just some moisture in the tails triggering a code. the occasional three beeps is the memo system. Used in europe 2 minutes before the hour to alert ou to tune to the hourly traffice reports.
Old 07-14-2006, 08:26 PM   #4
Rate My Car: 106 / 337
^^^Errr, 15sec before the hour
BRAKE LIGHT FAILURE means you have a bulb out.
BRAKE LIGHT CIRCUIT means there's a problem with the wiring, or the switch on the pedal is faullty. Sometimes it's just condensation, as chris mentioned.
Old 07-14-2006, 08:49 PM   #5
CAPiTUL
CAPiTUL's Avatar
Your Ride: 98 328i
It was Brake Light Circuit.
All my brake lights were working.
And, it went away once I shut the car off (didn't come back one when restarted a few minutes later). It was still raining a little bit when it happened, so I'm thinking you are probably right with the condensation guess. Anyway to seal it off so moisture doens't get in there?
I'll keep my eyes peeled to the clock the next time I hear those beeps, too.
ユナイテドビーマーはいいですよ!
Old 07-14-2006, 09:00 PM   #6
The seal goes bad between the tail light assembly and the car body. Don't know if you can actually buy that gasket, never looked into it. But you can use silicone or something else I guess.
Old 07-14-2006, 09:36 PM   #7
TJsBimm
Rate My Car: 222 / 337
Your Ride: 97 328i
It's the switch on the pedal, just have to replace that. It won't come back after you start it, but it will usually when the brake pedal is touched. Had it happen to me as well.
Old 07-14-2006, 09:41 PM   #8
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
Isn't brake light circuit failure the switch, my car does that sometimes and I bought the switch, that is connected to your brake pedal, and now it works, I forget where I found the DIY I believe it was bimmer forums. It seems to be a common e36 problem.
crap forgot to hit send link like 10 mins ago, but same thing tj said
Old 07-14-2006, 11:30 PM   #9
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
had that problem, changed the switch by the pedal, and it's been fine since
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 07-15-2006, 12:42 AM   #10
CAPiTUL
CAPiTUL's Avatar
Your Ride: 98 328i
Thanks folks. I will have to look into that and see if I can fix it before my trip up north.
ユナイテドビーマーはいいですよ!
Old 07-15-2006, 09:22 PM   #11
Alpine328i
Kind of off topic, but kind of ON topic...
Any recommendations for what to use to re-seal the tails? I have a leaky front corner too. Not leaky... but the seal's bad and I get moisture... you know what I mean... HAHA
---Bailey
"In the road of life there are Bimmers and there are Bimmers"
Mods: Full JDM lighting, APC bulbs, ///M rims, Four wheel Brembo rotors, Bilstein Touring suspension.
Old 07-16-2006, 03:30 AM   #12
Try new gaskets -
Old 07-16-2006, 09:25 AM   #13
Alpine328i
Will OEM gaskets fit aftermarket lights?
---Bailey
check control light Chris United Off Topic  **FOR MEMBERS ONLY** 5 06-16-2006 12:43 PM
Check Light? Empty Box E21, E30 5 05-04-2006 05:13 PM
ABS check light came on!!! please HELP!!!! delmarco E36 9 07-06-2005 08:27 PM
90k mile tune up BombSquad E36 1 04-28-2005 12:09 AM
