Old 06-25-2006, 10:46 AM   #1
cc-vortex
Rate My Car: 260 / 337
Your Ride: 1994 325i Sedan
Block fuses
Got up this morning to go get some coffee and my ABS and my ACS warning lights were on. I thought maybe it's a fuse issue, but I have no idea how to check those large block fuses to see if they're bad.
Anyone know how to tell when they've blown?
Thanks.
Old 06-25-2006, 11:06 AM   #2
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 128 / 337
i thought those were relays
edit: in fact, they are relays.
do you mean asc? active stability countrol?
Old 06-25-2006, 11:22 AM   #3
cc-vortex
Sorry, yes, ASC light...
Both the ABS and ASC lights are on.
Old 06-25-2006, 12:00 PM   #4
cc-vortex
OK, not sure if this helps with an answer, but I just went back out to my car and with the engine off I pumped the brake pedal three or four times, started the car and the lights went out.
I vaguely remember reading somewhere someone else having this same issue but for the life of me cannot remember what the fix was.
Old 06-26-2006, 02:58 AM   #5
Spieluhr
Title: ///M Driven
well glad you fixed it, and even better that it was something so simple.
Old 06-26-2006, 05:56 PM   #6
bitcore
bitcore's Avatar
could have been a low battery and your alternator has recharged your battery enough to make them STFU. these lights sometimes light up when the car dosn't have enough juice.
Old 06-26-2006, 11:25 PM   #7
cc-vortex
Oh, no, it's not fixed, the lights come back on after a minute or two
Old 06-26-2006, 11:33 PM   #8
bitcore
bitcore's Avatar
Sounds like you have a dieing voltage regulator on your alternator.
When cold, it works fine, but once heated up the components wont function properly and it ceases charging your battery.
Roll on over to autozone or some store to get it tested for free. If your in europe, I'm not sure where to suggest that you go but I'm sure some place will test it for free without the need to remove the alternator from the car.
Get this fixed soon as this process (cycling it's charge very deeply) will RUIN your battery.
Old 06-27-2006, 11:26 PM   #9
cc-vortex
I'll give that a try, thanks.
Although, the lights are on 24/7 now
Old 06-28-2006, 03:37 PM   #10
xxxbimmer
Rate My Car: 46 / 337
check your error codes......sounds like the problem could be related ......prob a sensor
Rolling road block Hoppy United Off Topic  **FOR MEMBERS ONLY** 14 04-03-2006 09:10 AM
m42 head w/m44 block e30boarder E21, E30 33 08-09-2005 04:19 PM
Fog Fuses Joey E21, E30 5 05-11-2005 10:34 PM
