Old 06-18-2006, 02:14 PM   #1
Spieluhr
Title: ///M Driven
susp. upgrade components (mounts, etc.)
ok, so my next upgrade is the suspension so my car doesn't look like a 4x4 any more.
I am getting Bilstein Sport shocks ($435 shipped new)
and probably H&R Sports 1.5" F/1.0" R ($225 +S/H)
now my question is, what other things will I need to install this? I know I should probably get new rear shock mounts, but aside from that, what else?
Old 06-18-2006, 06:26 PM   #2
Rate My Car: 106 / 337
You may need upper strut bearings, but that's kinda hard to judge until you pull the old struts out. Then maybe new coil spring pads, depending on how your current ones are faring (don't know if the new H&R's come with them?).
Old 06-19-2006, 06:02 AM   #3
O yea, just remembered . . people don't think this is important, but try to use all new hardware to mount the struts and shocks in, especially the mounting nuts on the shock towers. They're designed for one time use, because they slightly deform to lock in place once they're tightened down. If not, use a threadlocker, like Loctite 262. Pelican parts will have the nuts, they're the same for front and rear.
The upper strut-to-hub bolt & nut is a bear to remove because there's not much clearance to get a big ratchet in there to really crank on it. To get it loose, I jammed a breaker bar against the strut housing to exert more force:
Lastly, remember that the lower mounting bolt on the rear shock should be tightened down while the car is on the ground, not while jacked up.
Old 06-19-2006, 06:08 AM   #4
Rate My Car: 137 / 337
Make sure you get new front upper strut bearings. (It's just not worth doing the job twice.)
Old 06-19-2006, 07:59 AM   #5
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
Weren't you going to sell the car?
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 06-19-2006, 01:42 PM   #6
dinan540
dinan540's Avatar
^^^I thouhgt that too.
540i with some mods
Old 06-19-2006, 04:53 PM   #7
Spieluhr
Title: ///M Driven
that was an idea. not so sure any more.
Old 06-19-2006, 08:22 PM   #8
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
where are you getting bilstein sports for $435????
i'm doing my shocks next, the lowest price i found was $700 or so
Old 06-19-2006, 11:42 PM   #9
Rooz
Rooz's Avatar
Your Ride: 2003 M5
Trust me, if anyone knows how u feel... it'd be me..... But here is an idea, put your car on autotrader, just to see if you get responses. I put mine at a high price just to see what would happened, and I sold it for a price that I was good with (higher than my rock bottom)...
Old 06-20-2006, 12:05 AM   #10
Spieluhr
Title: ///M Driven
yeah, the only problem with that is, I still owe money on it, and I dont want to have to pay it all off, then finance again, or buy something for less.
Old 06-20-2006, 12:09 AM   #11
Spieluhr
Title: ///M Driven
http://www.performancepartsstore.com...ein%20deal.htm
Old 06-21-2006, 09:50 AM   #12
mullethunter3
thanks
DIY (please sticky):Blown Rear Shock Mounts!? E36 Tower Complete Replacment! delmarco BMW OEM Parts Department DIY's & FAQ's 9 08-27-2005 02:16 PM
Upgrade Help!! komodo E36 25 06-16-2005 12:19 AM
JT-Designs Rear Shock Mounts GB Special Jon@MPerformance Bmw Cars For Sale/Wanted 4 05-03-2005 01:44 PM
