Old 06-03-2006, 11:57 PM   #1
camilo27
camilo27's Avatar
Your Ride: 328is 1996
Thumbs up ignition swich help
I tried to change the igniton swich from my 328 is 96,it is almost imposible for me to install the new one. To take off the old one, I had to drill it. If some one can give a advice would be great.
camilo27us@yahoo.com
Old 06-04-2006, 12:02 AM   #2
camilo27
camilo27's Avatar
ignition swich problem
[QUOTE=camilo27]I tried to change the igniton swich from my 328 is 96,it is almost imposible for me to install the new one. To take off the old one, I had to drill it. If some one can give a advice would be great.
Old 06-04-2006, 12:49 AM   #3
Rate My Car: 183 / 337
what problems are you having exactly? ive done this before, the only way to get the bolts off is to take a chisel to them, they break them at the factory for safety reasons, i was told, but what other trouble were you having, you do know that you have to take the steering wheel off, right?
Old 06-04-2006, 01:07 AM   #4
camilo27
camilo27's Avatar
Hi, thank you for answer. I have the new swish I tried to put it on and dont click. I dont know if I have to take off the steering wheel I tried to get some advise before I get crazy.
Old 06-04-2006, 01:15 AM   #5
either way, you have to take off the steering wheel, its actually not that hard, 1st, disconnect the battery, then, there are four star screws, on the back of the steering wheel that will pop the airbag out(atleast this is on a 92 325i), once the airbag is out, unplug it, and then there are a few bolts for the actual steering wheel itself, its very self explanatory from there
Plasma Ignition System Rooz E36 25 03-15-2006 10:58 PM
High performance Ignition coils Rooz E36 33 03-06-2006 03:48 PM
No Battery Voltage to Starter singring E36 2 01-09-2006 09:20 PM
Need DME Ignition Transistor singring E36 1 12-15-2005 10:28 AM
She Ok! Cellardoor M3 11 10-28-2005 12:10 PM
