Old 06-02-2006, 01:53 PM   #1
cabrit
cabrit's Avatar
m3 exhaust question
i finally install my m3 exhaust on my 1994 325i
to tell you the truth it feels kind of funny it seems that i have lost power on low rpm and feel a little gain on high rpm at time it almost feeels like something is holding it back from taking off. is this suppose to happen or something is wrong with the exhaust. or should i have also change to m3 catalytic converter. or is it something totally different
what do you guys think
thanks
Old 06-02-2006, 03:32 PM   #2
Rate My Car: 137 / 337
Have you done anything ti increase intake? (manifold,etc) All you did is increase it's breathing ability and I suspect the flow helped your upper end and took away from lower end. You need to increase the intake capacity. Whenever you "mod" performance, you're taking the factories' set 100% and "unbalancing" what they provided increasing one end but decreasing at another.
Old 06-02-2006, 04:22 PM   #3
cabrit
cabrit's Avatar
somebody mentionned getting headers
what should do you think i should do
Old 06-02-2006, 05:03 PM   #4
Headers are a toss-up - depending on how they're made. The longer they are, the more top end you'll gain (but lose on lower end). The shorter they are the more torque you'll gain on bottom end but then the top end suffers. (I have adjustable headers on my bird and that's for tuning at the track for temp, surface and other variables)
Personally, for a street driven car, I'd avoid them - they don't wear well for year round driving, they generate ALOT of heat, they're noisy, and finding ones to fit your driving (in all conditions) can be tough & costly.
First decide where you want your power band and consider all conditions (year round weather, the types of driving your planning on doing not just those blasts down the highway, and the "big-gees" - what you're willing to spend on mods & maintenance.) I'm an advocate for mods as long as you know what the repercussions are before learning at your wallets' expense.
Old 06-02-2006, 06:36 PM   #5
ChrisWorrell
Your Ride: 2004 330i
The reason you feel a little less down low is because the m3 has less resistance to the travel of air so there is less backpressure which is a key aspect of Torque. The reason it feels stronger on the high end is because it is breathing stronger and as you speed up more air is able to pass through the exhaust since there is less resistance.
The perfect solution to a loss of low end torque. A twin screw superchager
Old 06-06-2006, 12:19 AM   #6
MrWonka
MrWonka's Avatar
Your Ride: 94 325is
You wont see much difference in sound from a stock exhaust to an M3 exhaust unless you gut it, which would make it pretty loud. Since your OBD1 another option is to get OBD2 cats which are more freeflowing and then gut the M3 exhaust, should get some more power/sound out of it.
Peace
-Mike
Old 06-06-2006, 12:22 AM   #7
Chris
Chris's Avatar
Title: Visiting Mod
no. there's a difference... let me go start it up.... yeah, there's a difference.
Old 06-06-2006, 05:45 AM   #8
Rate My Car: 106 / 337
Would a CAI help to balance it out somewhat?
Old 06-06-2006, 11:00 PM   #9
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
CAI would definetely help with an exhaust.
Old 06-08-2006, 12:56 AM   #10
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
exhausts on there own are not going to do much for performance. its more ofr the look and sound.
Old 06-08-2006, 09:48 PM   #11
MrWonka
MrWonka's Avatar
Your Ride: 94 325is
Like B.W. said, exhaust will give you like 5 hp max, an exhaust and CAI will give you a nice sound together and give about 10 hp or so, some companies claim around 15 hp or so alone for CAI's.
Mike
Old 06-09-2006, 10:21 PM   #12
B_w.
and dont waste your money on headers. if you want some good power go ith the m3 cam kit from eurosport
Old 07-04-2006, 02:08 PM   #13
LWRNCE
Rate My Car: 4 / 337
Your Ride: E36
You didnt gain anything... You lost low-end torque and gained weight. The E36 M3 exhaust is heavy. Very Heavy. You traded loss in performance for sound.
M3 SMG vs Mini Cooper S komodo BMW General Discussion 1 10-31-2005 11:18 AM
M3 Exhaust or Intake Vote now! ///Menace328i E36 28 07-17-2005 04:55 PM
FS Locally: M3 Exhaust mpowerd Bmw Cars For Sale/Wanted 7 07-13-2005 03:08 PM
M3 exhaust Rooz E36 13 06-05-2005 09:09 PM
History of the M3 komodo United Off Topic  **FOR MEMBERS ONLY** 9 06-05-2005 06:16 PM
