alright, got my alignment, with print out and everything.
I went to Les Schwab, cost me about $80. and everything was good except the steering was a little off, and right rear camber was right on the edge (-1.9 degree).
So got it all fixed, and feel more at ease now.
you got an alignment for 80? Thats cheap seeing that to align a BMW correctly well at least for my e36 I was told there has to be 500 pounds in the car. Im getting it done next week for $120 ish.
My rear camber is messed up too...
... and from what i read, i guess it is just a matter of bringing my car to a shop and have them align it.
The thing is, i did this already, (brought it to El's Tire in Glasgow, DE) and i explicitly told them to see if they can fix the rear camber, (while doing the alignment) and they didn't, and when i asked the mechanic what may be causing the camber, he said i needed new springs. So i got a set of H&R OE springs, (0.5" rear, 1.0" front) and nothing changed. the front got lowered, but the rear was still F-ed.
So from reading this post i guess what i am going to do is bring my BMW to a more competent shop to have the rear camber adjusted.
thank you United Bimmer!
Your Ride: '96 328is
Originally Posted by Dudesky
It's the front camber that isn't adjustable, although changing the size of the upper hub to strut bolt can make up to a 1 degree difference.
I just lowered my e36 and the front camber is sightly off while the back looks okay. I think this bolt could do the trick for me, at least its worth a try. Can you buy this bolt somewhere, or do you have to customize it? thanks
