Old 05-25-2006, 07:48 PM   #1
singring
How Do You Release Timing Chain Tensioner ??
I have a 1995 318i and I my replacement timing chain tensioner (original M42 type with spring) has arrived. I have read the Bentley manual, and I understand about compressing the tensioner prior to installation...however, the Bentley manual refers to a complete timing chain overhaul, which involves the removal of the timing chain cover...after the tensioner has been installed, Bentley says on page
117-5 #11 "On M42 engines: Release early-style chain tensioner by pressing chain guide against tensioner until it unlocks and expands out."
Well, I am just replacing the chain tensioner, without removing the timing chain cover, etc.....so, my question is:
1. How do I go about releasing the chain tensioner once it is installed?
2. How will I know if the tensioner has, in fact, released itself and expanded?
If the tensioner is not expanded against the chain guide, engine damage will occur, but how can I accomplish releasing the chain tensioner if I can't access the chain guide because the timing chain cover has not been removed?
Any help is greatly appreciated...thanks
Old 05-27-2006, 06:45 AM   #2
Rate My Car: 106 / 340
**Bump**
I really hate to see a good question like this unanswered. I've seen your posts on other forums too, unanswered. Surely someone must have insight to this. I read the Bentley as well, and it doesn't seem too clear . . looks like you may have to remove the cover
Old 05-29-2006, 11:26 AM   #3
singring
I have recieved some good answers from other forums....once installed, start engine. You will hear the chain rattle somewhat, but this will cause the chain guide to push against the tensioner, thereby releasing it.
Thanks for the support, Dudesky !!
Old 05-29-2006, 03:15 PM   #4
Chris
Chris's Avatar
Title: Visiting Mod
NO!
if you start the engine without getting the timing chain tensioner to re-engage, there will be no pressure on the chain and the cams will get all f'ed up and you're going to end having a valve hit a piston head and then you're gonna be shit up a creek without a paddle unless you know how to replace a piston and most likely piston arm including journals by yourself.
Replacing timing chain tensioner...need help !!! singring E36 2 05-16-2010 04:23 PM
318i Timing Chain Rattle singring E36 2 05-12-2006 12:34 PM
318i Timing Chain Rattle singring E36 0 05-11-2006 11:14 PM
Vanos komodo E36 16 05-31-2005 08:32 PM
Timing belt? popzalock E21, E30 6 04-25-2005 12:44 PM
