Old 05-11-2006, 10:23 PM   #1
singring
318i Timing Chain Rattle
I have a 1995 318i , automatic, 127,000 kms. Last few weeks there is a chain rattle noise occuring from engine area, when car idles from cold start. Once car is revved up, the rattle goes away. I am thinking the timing chain tensioner need replacing. Previous posts indicate this is a very easy, and inexpensive job. I have a Bentley manual, and I will be following it when changing the part. But, I was wondering if the timing chain can be observered with cover off, and engine running. Probably NOT !! So, when I remove the cover, and inspect the chain, how will I know if the tensioner needs to be replaced? Should there be ANY slack in the chain? Anything else I should be looking for?
Thanks
Old 05-11-2006, 10:30 PM   #2
doughboyea
doughboyea's Avatar
Your Ride: 2007 Acura TSX
I'm just going to throw this out there.....
I don't want to lead you wrong, though, my best guess, it's shouldn't be loose, but it's not suppose to be rock hard either. Now, I'm no mechanic, but, replace tensioner if it's obviously weak, where it can't hold onto the chain for a snug fit.
Other's will post about this, more likely with more detail than with what I wrote out. Wait for them to confirm or reject what I said.
Dough
Current Ride
2007 Acura TSX w/Navi
Past rides:
1989 Mercedes 190E 2.6
1980 Mercedes 240D
Old 05-12-2006, 12:34 PM   #3
singring
Is it REALLY this complicated ??
Well, I quickly looked through the Bentley manual, and contrary to some posts, this is a very involved repair. Is it really necessary to drain the engine oil, drain the coolant, remove the fan and shroud, disconnect the hoses from thermostat housing?? Every post I've seen suggests this is a 10-15 minute job....am I missing something here?
Your advice is appreciated
Thanks
What is the avg. lifespan of an Auto M42 E36 318i? delmarco E36 15 05-31-2005 11:09 PM
Vanos komodo E36 16 05-31-2005 08:32 PM
Timing belt? popzalock E21, E30 6 04-25-2005 12:44 PM
